Wired Intelligent Edge
STP disconnect firewall LAN port
  • 1.  STP disconnect firewall LAN port
    Posted Feb 20, 2016 10:58 AM
    We have a firewall connected in one HP procurve 2610 switch port
    and another to an internal switch procurve HP 2910. In the first switch (2610) we have
    connected the router and in 2910 HP the servers and other final client PCs switches (stacked 2610)
    Among all the switches is enabled MRSTP.
    It's happened a few times a very strange effect is that LAN firewall port (connected to
    2910) stops working and the light from port of the internal switch is turned off.
    Removing and reconnecting the cable to the switch will fix the problem, which seems rather odd.
    The firewall is a Dell PowerEdge Linux Lince and Ethernet Dual Port Broadcom 5720 NetStreme 100 Mbps card.
    The logs of HP2910 shows the following sequences of these events repeated several times: - Port X is now off-line - Port X is Blocked by STP - Port X is now on-line -ffi: Port X-Excessive Broadcasts. See help. - Port X is now off-line - Port X is Blocked by STP where X is the LAN port on the firewall, ie the STP blocking port.
    I checked cables between switches that the firewall is connected
    and there is no physical loop.
    On the other hand the situation, using switches commands, is characterized by:
    -there is no change of STP topology
    -topology changes counter doesn't increase
    -STP on the switch blocks LAN firewall port
    Software releases are: W.14.03 for 2910 and R.11.25 for 2610. I checked fixes but I
    couldn't find any related with MRSTP or Broadcom NICs. Does anybody what's happening?
    Best Regards and thanks in advance.
    #firewall
    #ProCurve
    #HP2910
    #STP
    #hp2610
  • 2.  RE: STP disconnect firewall LAN port
    Posted Feb 22, 2016 11:31 AM
    Hi there,
    have you have setup the spanning tree priorities on all of the switches?
    Dom
  • 3.  RE: STP disconnect firewall LAN port
    Posted Feb 22, 2016 02:34 PM
    No,
    Priorities are all by default, ie 32768 in all switches. Firewall port is in 2910 tandem switch (I mean there are two witches, one of them is connected to LAN port firewall and the other to serves, they are connected both together) and the other WAN port in 2610 switch where router is connected. The root is one of the switches of the tandem, where the firewall isn't connected. All the switches have the same priority, default priority. The strange question is despite of STP blocks LAN port, you don't see a topology change and the counter isn't increased. On the other hand this problem has happened four times with the same effects.
  • 4.  RE: STP disconnect firewall LAN port
    Posted Feb 23, 2016 08:41 AM
    You should definitly think about setting up the priorities, unless your tandem switches are in a stack, do you manage them both from 1 IP address?
    For spanning tree on our switches, we tag the switch which has the primary route with the lower number, for example
    There is a site with 3 switches: all switches are connected, switch 1 is connected to both 2+3, switch 2 is connected to both 1+3 and switch 3 is connected to 1+2.
    Switch 1: has our Primary Router attached, we give that switch a priority of 0 (CLI code "spanning-tree priority 0")
    Switch 2: has our Backup Router attached, this switch is given a priority of 2 (CLI code "spanning-tree priority 2")
    Switch 3: no router, this switch is given a priority of 15 (CLI code "spanning-tree priority 15")
    From what you have said I would suggest the switch with the firewall having a priority of 0.
    A colleague also suggested that you look into setting a spanning tree edge port, if your switch will let you do this, that would be setup on the interface that connects to the firewall. This will stop it blocking the port in the event of finding a loop, we only set these up on interfaces we know will not get a loop.
  • 5.  RE: STP disconnect firewall LAN port
    Posted Feb 23, 2016 10:09 AM
    Maybe this isn't a STP problem:  STP won't bring down the link when blocking a port.
  • 6.  RE: STP disconnect firewall LAN port
    Posted Feb 23, 2016 04:42 PM
    Hello 16again,
    What do you suggest? Any idea that could produce this situation?
  • 7.  RE: STP disconnect firewall LAN port
    Posted Feb 23, 2016 05:05 PM
    If you manually unplug a port, you'll also end up with "blocked by STP" message, but STP isn't the cause , just the result
    Try forcing speed/duplex settings on both sides of trouble link.
    Look into error counters on port (on both sides)
  • 8.  RE: STP disconnect firewall LAN port
    Posted Feb 23, 2016 05:51 PM
    Hi 16again,
    Any other situation that can show the same STP effects without physical unplugging cables?
    With counters, what can you see?. For example in this case for X port blocked by STP
    Totals (Since boot or last clear) :
    Bytes Rx : 2,948,646,096 Bytes Tx : 1,937,188,467
    Unicast Rx : 3,501,949,778 Unicast Tx : 2,725,757,392
    Bcast/Mcast Rx : 2,407,356 Bcast/Mcast Tx : 96,320,597
    Errors (Since boot or last clear) :
    FCS Rx : 1 Drops Tx : 34,918
    Alignment Rx : 0 Collisions Tx : 0
    Runts Rx : 0 Late Colln Tx : 0
    Giants Rx : 0 Excessive Colln : 0
    Total Rx Errors : 1 Deferred Tx : 0
    Others (Since boot or last clear) :
    Discard Rx : 0 Out Queue Len : 0
    Unknown Protos : 0
    Rates (5 minute weighted average) :
    Total Rx (bps) : 0 Total Tx (bps) : 0
    Unicast Rx (Pkts/sec) : 0 Unicast Tx (Pkts/sec) : 0
    B/Mcast Rx (Pkts/sec) : 0 B/Mcast Tx (Pkts/sec) : 0
    Utilization Rx : 0 % Utilization Tx : 0 %
    Thanks in advance.
  • 9.  RE: STP disconnect firewall LAN port
    Posted Feb 24, 2016 01:50 AM
    FCS counters look suspicious:
    "FCS Rx : 1 Drops Tx : 34,918"
    Just try forcing link duplex/speed on both sides, and replace the UTP cable by a brand new CAT6
  • 10.  RE: STP disconnect firewall LAN port
    Posted Feb 24, 2016 12:19 PM
    Hi 16again,
    So you think it is a problem of speed and cable, no? The strange for me is that the problem had only happened three times (one in 2014, one in 2015 and another in 2016 with the the same effects and logs)  and if the cable or speed adjustment are bad, it shouldn't happen more often?
    Thanks again for tour early answer.
  • 11.  RE: STP disconnect firewall LAN port
    Posted Feb 23, 2016 04:41 PM
    Hello DDgrus,
    Thanks for answering.  tandem switches are in a stack and they are managed them both from 1 IP address.
    "A colleague also suggested that you look into setting a spanning tree edge port, if your switch will let you do this, that would be setup on the interface that connects to the firewall. This will stop it blocking the port in the event of finding a loop, we only set these up on interfaces we know will not get a loop."
    It is a possibility, but why a loop, there aren't physical cables between them doing lopps.
  • 12.  RE: STP disconnect firewall LAN port
    Posted Feb 24, 2016 04:05 AM
    This command has to be used very carefully, but it can be very useful at connection points/borders where there are mismatched (or unknown) STP settings coming together. It can cause problems and it almost certainly won't work if you have multiple connections.
    On the ProCurve port where the connection is coming in:
    spanning-tree 24 bpdu-filter
  • 13.  RE: STP disconnect firewall LAN port
    Posted Feb 24, 2016 04:32 AM
    Perhaps there may be problems due to incorrect setup Ethernet Dual Port Broadcom 5720 NetStreme
  • 14.  RE: STP disconnect firewall LAN port
    Posted Feb 24, 2016 12:11 PM
    Hi Richard,
    Thanks for answering. What do you mean by:
    "there are mismatched (or unknown) STP settings coming together"
    On the other hand
    Where do you propose to apply, LAN firewall port (2910) or WAN firewall port switch (2610). Firewall works in bridge mode and  it doesn't use STP, I mean, it only forwards BPDUs from one to antoher switch port. If I filter BPDU I will have two different STP trees, one for the border switch (router port and WAN firewall port) and another for the rest of switches (all connected to the firewall LAN by one port of 2910 switch), no?
    Best Regards and thanks.
