Wired Intelligent Edge
STP is not enabled by default Aruba 5406Rzl2 switch running Aruba OS version - KB.16.10.0009
  • 1.  STP is not enabled by default Aruba 5406Rzl2 switch running Aruba OS version - KB.16.10.0009
    Posted Jul 10, 2022 08:08 AM
    Dear All,
    I would really appreciate if you all give  your insights regarding this issue.
    I issued show spanning-tree vlan xx in Aruba 5406Rzl2 switch and it says stp mode is MST and STP is not enabled. Does this means I will have to enable spanning tree in the switch and I would appreciate if some one can let me know how does STP works in Aruba OS.
    Thank you and Regards,
    Gayan
  • 2.  RE: STP is not enabled by default Aruba 5406Rzl2 switch running Aruba OS version - KB.16.10.0009
    Posted Jul 10, 2022 08:14 AM
    Hi Gayan,
    "In the factory default configuration, spanning tree operation is off" https://www.hpe.com/psnow/doc/a00091310en_us , page 91.
    So yes, you need to enable STP if it wasn't enabled before during previous configuration sessions.
    Ivan Bondar
