Cloud Managed Networks
  • 1.  Sub Sites
    Posted May 09, 2023 11:46 AM
     Howdy!
    Within Aruba Central is there any such thing as "Sub-Sites". We'd like to have a main site, then be able to look at the sub sites within the main site, if you catch my drift.
  • 2.  RE: Sub Sites
    Posted May 09, 2023 12:15 PM
    Quick answer is no. Nothing available along those lines.
    However, you can accomplish a similar monitoring/reporting functionality using "labels"
    Devices can be assigned multiple labels.
    Labels can be used as a filter in any Site View, they can also be quickly segmented in a report, by using Global Label view.
    Managing Sites and Labels (arubanetworks.com)
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Sub Sites
    Posted May 09, 2023 12:19 PM
     Thanks for your help! You actually gave me some ideas that I'll experiment with, I have to design/map out over 100 buildings. Again, your help is much appreciated!
