Network Management
Suppoted instant APs on Airwave 8.2.15.1
  • 1.  Suppoted instant APs on Airwave 8.2.15.1
    Posted Aug 18, 2023 01:29 PM
    Hello, i saw the matrix of this but i want to know if i understant it clearly
    on the matrix it says that for ArubaOS( I balive it referring to campus APs model) it supports until 8.11.0.x
    What about for the instant APs??? its the same until 8.11.0.x? at least you can upgrade an ap 303 to 8.11.1.2 so its not 8.11.0.x  Will.  If i have a 303 that is on 8.9.x and i upgrade it to 8.11.1.2 will be able to still monitor it without issues?
    Later i see another table
    Which i bealive applys only but when you are managing APs centrally with airwave which im not doing, im just monitoring them.
    I just want to monitor them and that it get all the information correctly
    Im kind of confused here
    Someone can help?
  • 2.  RE: Suppoted instant APs on Airwave 8.2.15.1
    Posted Aug 19, 2023 03:10 PM
    It will work, yes.
