hello, I have a problem with a switch switch 1910 JE006A.
my version of firmware is the latest , but check with previous versions and gives the same problem.
to create a VLAN interface. not the dynamic route is created:
*1 10.20.0.1 /24 UP MANUAL
10 10.20.10.1/24 UP MANUAL
20 10.202.20.1/24 UP MANUAL
0.0.0.0 255.255.255.0 Static 1 10.20.0.1 Vlan-interface1
127.0.0.0 255.0.0.0 Direct 0 127.0.0.1 InLoopBack0
127.0.0.1 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
10.20.0.1 255.255.255.0 Direct 0 10.20.0.230 Vlan-interface1
10.20.0.230 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
this is normal? I would not have to add me routes to these interfaces as it does with VLAN 1
Thank you!
