Wired Intelligent Edge
  • 1.  Switch 6300M stacking.
    Posted Nov 29, 2023 02:32 PM
    Can we stack 6300 switch using on transceivers/ fiber? I didn,t order stack cable.
  • 2.  RE: Switch 6300M stacking.
    Posted Nov 30, 2023 05:31 AM
    Edited by parnassus Nov 30, 2023 05:33 AM
    Yes, why not? provided that you follow the VSF Guide for setting up the Aruba CX 6300 VSF stack and you use original Aruba SFP+ Transceiver (here I am implying that you are going to use original Aruba SFP+ Short Range (SR) LC Transceivers and certified OM3/OM4 MM Fiber Optic patch cables to setup the required VSF Links based on 10Gbps throughput - as the bare minimum - in substiturion of Aruba 10G DACs). It's going to work as you expect even without the usage of cheaper Aruba 10G DACs.
  • 3.  RE: Switch 6300M stacking.
    Posted Nov 30, 2023 05:34 AM
    Thank you for feedback
