Wired Intelligent Edge
  • 1.  Switch aruba 6100 DHCP SNOOPING
    Posted Aug 14, 2023 10:30 AM
    I'm trying to activate DHCP Snooping to pass DHCP but I can't use the command, it doesn't exist in the 6100?
    Config:
    6100(config-if)# int 1/1/47
    6100(config-if)# dhcpv4-snooping
    Invalid input: dhcpv4-snooping
    6100(config-if)# config
    6100(config)# dhcpv4-snooping
    6100(config)#
  • 2.  RE: Switch aruba 6100 DHCP SNOOPING
    Posted Aug 15, 2023 04:06 AM
    According to the Feature Navigator, dhcpv4 snooping should be available on the 6100 starting with the 10.09.0002 release. Are you on that release or newer?
  • 3.  RE: Switch aruba 6100 DHCP SNOOPING
    Posted Aug 28, 2023 04:25 PM
    Thank you!
