Comware
  • 1.  Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Jun 30, 2011 10:48 AM
    I've got two switch baseline 2928 SFP Plus, when I connect both with a optic fiber (e.g. in both SFP ports 28), I don't have links.
    The syslog shows me these two messages:
    2:34:43:947 2000  OPTMOD Warning MODULE_IN GigabitEthernet1/0/27: The transceiver is SFP_UNKNOWN_CONNECTOR.
    Apr 26 12:34:43:947 2000 OPTMOD Error TYPE_ERR GigabitEthernet1/0/27: The transceiver type is not supported by port hardware!
    But, when I disable and then enable one of them from Port Management (SFP Ports 28) I've got link.
    I have read old posts and I try to hard code speed and duplex to 1000 full to get the link to come up, but I can not perfom these changes. I´ve got this message "GigabitEthernet1/0/28 (Speed)  Operation not supported!".
    in ports without fiber connection (e.g. SFP port 27) I can perform those changes.
    *Both transceivers specifications are:
    AVAGO AFR-57R5APZ
    850nm LASER PROD
    21CFR(J) CLASS 1
    CHINA 1001
    *Software Version Release: 1101P07
    any idea?
    thanks!
  • 2.  RE: Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Jun 30, 2011 12:45 PM
    Probably, the problem is associate with the model of transceiver that you are using that can be a not approved transceiver.
  • 3.  RE: Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Jun 30, 2011 01:39 PM
    Hi Luciano,
    Yes, I suspects that it's the problem.
    Thanks!
  • 4.  RE: Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Jun 30, 2011 02:28 PM
    Luciano,
    Could be a problem with the port configuration or something else about that?
    Regards.
  • 5.  RE: Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Jul 01, 2011 06:34 AM
    I can use Cisco, SMC, Netgear coded SFP modules with my 3Com 2928 switches. So that´s not the problem.
    Try upgrading your firmware to release: V1900_5.20.R1108 (HP V1910 == 3Com 2928)
    https://h10145.www1.hp.com/downloads/SoftwareReleases.aspx?ProductNumber=JE006A&lang=de&cc=de&prodSeriesID=4218346
  • 6.  RE: Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Jul 01, 2011 09:47 AM
    I upgraded to V1900_5.20.R1108, but, it was worse.
    I didn't have links in both ports and I couldn't have links when I was disabling and enabling ports.
    thanks anyway!
  • 7.  RE: Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Jul 01, 2011 10:27 AM
    Sorry, but I correct transceivers specifiactions (I lost the letter "B" in model number):
    AVAGO AFBR-57R5APZ
    850nm LASER PROD
    21CFR(J) CLASS 1
    CHINA 1001
    Pdf specifications:
    http://www.avagotech.com/docs/AV02-0881EN
    Attach logfile_logfile, startup.cfg and system.xml (attachment.zip)
    Thanks!
    Attachment(s)
    zip
    attachment.zip   703 B 1 version
  • 8.  RE: Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Jul 02, 2011 04:24 AM
    Is this a fibre channel SFP module? It seems so: http://en.wikipedia.org/wiki/Fibre_Channel
    This will never work in a standard ethernet switch. You do need a ethernet SFP one:
    http://en.wikipedia.org/wiki/Gigabit_Ethernet
    Depending on your cabling you need, e.g 1000Base-SX for multimode fibers or 1000Base-LX SFPs for singlemode fibers.
    Whoever you sold that combination...
  • 9.  RE: Switch baseline 2928 SFP Plus - SFP ports do not always bring links Up
    Posted Dec 09, 2011 01:05 AM
    Is this issue resolved already?
    Can you please reset the module. This looks like issue with the module.
    Also if resetting the module doesn't work. Please replace the module with the new one and check if that works.
    Vibha Jha.
