Hi
New here, so treat me kindly, please.
We have a query which I was told by HP to post here. Am trying to troubleshoot a problem and just want to confirm some facts.
The question is, does an individual ASIC in a switch control a set of six ports, or is it something else. Reason for the question is we have some device on our network which is occasional flooding the network and the switch counters are showing high levels of abort packets. What we are seeing is that the number of abort packets are very similar level on ports 1 to 6, but then a very different similar number on ports 7 to 12 and so on.
I need to rule out whether the number of aborts are based on the ASIC or some other aspect of the internal workings of the switch, or is to do with the devices connected at the other end of the links. Obviously, devices connected at 100Mbs are seeing significantly higher numbers, but for devices connected, at the same speed on the ports, the number of aborts are very similar but in groups of 6.
Anyone know the answer to this.
Carrick
P.S. This thread has been moved from ProCurve / ProVision-Based to Comware-Based. -HP Forum Moderator
