I wouldn't assume that a particular feature works in the simulator just because there is a lab for it. Every time I've tried the Spanning Tree labs they've failed with spectacular broadcast storms even though it's a supported function and the labs say it works.
Tommyd, have you tried it and been unsuccessful or were you just wondering if it was supported before trying it?
Original Message:
Sent: Nov 17, 2023 09:49 AM
Subject: Switch Simulation Software Features
Did you look here:
simulator community
https://community.arubanetworks.com/community-home?communitykey=aa40c287-728e-4827-b062-5eff4ed6410b
Proposed labs
https://community.arubanetworks.com/discussion/using-the-aos-cx-switch-simulator-lab-guides#bmee47602d-861e-407a-a269-1cd1f00725e0
VSX (part1):
https://community.arubanetworks.com/community-home/digestviewer/viewthread?GroupId=565&MessageKey=f0817458-0015-4e9d-98fc-b7fc3d405bdc&CommunityKey=aa40c287-728e-4827-b062-5eff4ed6410b&tab=digestviewer&ReturnUrl=%2fcommunity-home%2fdigestviewer%3fcommunitykey%3daa40c287-728e-4827-b062-5eff4ed6410b%26tab%3ddigestviewer%26SuccessMsg%3dThank%2byou%2bfor%2bsubmitting%2byour%2bmessage.
CX simulator supports also EVPN, and since 10.13 does support L3VNI (symmetric IRB)
Original Message:
Sent: Nov 16, 2023 05:22 AM
Is there anyone from the Switch Simulation Software team?
Are there plans or it is even possible for the simulator to have VSX and/or EVPN functioning? It would allow me to model my core infratructure and lab all planed changes before I break something important
-- tommyd
