Network Management
switch stacking-swapping commander
  • 1.  switch stacking-swapping commander
    Posted Jun 11, 2019 09:10 AM
    So i have a 2 x 2930M stack and the commander 1 has some blinking ports with errors.
    Can i add a sw3, then take out 1 and not have to reconfigure anything?
    i know they will reboot a few times possibly.
    or should i just make sw2 commander, add 3, then take out 1?
    running latest OS
  • 2.  RE: switch stacking-swapping commander
    Posted Jun 11, 2019 05:21 PM
    Hi!
    Please refer to the "Backplane Stacking Maintenance and Troubleshooting" chapter of the Aruba Backplane Stacking and VSF Best Practices on ArubaOS-Switch (ArubaOS-Switch 16.08) Technical Whitepaper...especially if you're going to add a new Backplane Stacking member (and consequently force the Commander member failover to Standby member before replacing it with a new unit) or if you're planning to replace the actual Commander.
