Comware
  • 1.  Switch troubleshooting
    Posted Oct 08, 2018 10:06 AM
    hello
     i have an hp 1910 series switch that is not working properly
    the power led blinks and 4 ports have stable green light even thought no cable is connected
    i update the firmware , reinitialized the swtch ( to factory settings ) and even disabled the ports but they are still green
    what can i do ?
  • 2.  RE: Switch troubleshooting
    Posted Oct 09, 2018 03:53 PM
    Dear Customer,
    Kindly help with the Product number of the HP 1910 series switch.
    Request you to check the following article, which has few information with LED on 1910 switch here.
    https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c04349441
    If the above information alleviates your query, don't forget to click Kudos!
  • 3.  RE: Switch troubleshooting
    Posted Oct 10, 2018 01:10 AM
    There is a possibility that the ports are failing self test and may require a RMA. Do you see any events in the log buffer related to these ports.
  • 4.  RE: Switch troubleshooting
    Posted Oct 10, 2018 03:49 AM
    even after disabling the ports they are still solid green .
    i will check the logs , but i am sure it's warranty has expired
