Comware
  • 1.  Switches resets time to 01/01/90 01:00
    Posted Mar 03, 2009 03:58 AM
    my HP 2900 switches has a time-synchronization issue. Look at the log:
    I 02/27/09 22:03:55 mgr: SME SSH from 192.168.0.29 - MANAGER Mode
    I 02/27/09 22:04:18 mgr: SME SSH from 192.168.0.29 - MANAGER Mode
    I 02/27/09 22:06:23 mgr: SME SSH from 192.168.0.29 - MANAGER Mode
    I 01/01/90 01:00:00 SNTP: updated time by -604619044 seconds
    I 01/01/90 01:00:00 SNTP: updated time by -720 seconds
    I 02/28/09 00:56:03 SNTP: updated time by 604626243 seconds
    I 01/01/90 01:00:00 SNTP: updated time by -604634163 seconds
    I 02/28/09 03:56:03 SNTP: updated time by 604637043 seconds
    Time/Date is reset to 01/01/90 01:00:00
    It happens every night during the same time-window.
    I know that server backups are running during the night, causing some network traffic, but not so much (i didn't get an alarm about high drop rate / overbandwidth).
    NTP server is a Linux Box, and from its logs all looks fine. Other devices syncing with it does not experience the strange time-reset issue. It happens only on ALL my procurve switches (even on the 8212 Core!).
    Switch sntp config is as follows:
    timesync sntp
    sntp unicast
    sntp server priority 1 192.168.0.200
  • 2.  RE: Switches resets time to 01/01/90 01:00
    Posted Mar 03, 2009 06:01 AM
    Hi Alberto
    For the issue you are seeing I would suggest you log a call with Procurve.
    HTH
    Gerhard
  • 3.  RE: Switches resets time to 01/01/90 01:00
    Posted Mar 03, 2009 11:04 AM
    Very strange. Get a packet capture from the NTP server when it occurs and see if you can figure out what might be causing it. All my switches sync to a 2003 DC without any problems.
  • 4.  RE: Switches resets time to 01/01/90 01:00
    Posted Mar 05, 2009 06:29 AM
    OK
    I verified that if I use the Windows 2003 DC all is fine (clock is OK). Strange, because the DC syncs with the above mentioned Linux server!
    I think it's some incompatibility between Procurve and my Linux box... every other machine/equipment does not experience this issue. I have to check if sntp daemon is fully RFC compliant.
