yes generally when you have Instant APs that are managed by Aruba Central and you want different VLANs for various clients that connect, then you need to configure VLAN trunking on the switches ans allow the VLAN IDs that you require.
Remember the Instant APs are not routers.
the default gateways for each of those VLANs will do the routing.
Original Message:
Sent: Jul 08, 2022 03:48 PM
Subject: Switchport TRunk
Hi Airheads,
Setting up Central/AP 535's for the first time . The Cisco system I inherited to replace had the AP cisco switchports set to a vlan . Don't think this is correct and am going to Trunk the switchports . Is it the best procedure to Trunk the switchports for all the AP's so they can route all the vlans on the cisco network
Thanks for reading
