Cloud Managed Networks
Sync switch to Aruba Central
This thread has been viewed 33 times
  • 1.  Sync switch to Aruba Central
    Posted May 18, 2025 05:27 AM
    I changed some configurations from CLI on the switch, now the switch is not in sync on Aruba Central, can I synchronize the configurations? I would like to keep the changes I made manually from CLI.
  • 2.  RE: Sync switch to Aruba Central
    Posted May 18, 2025 07:19 PM
    is this a CX switch? can't you do the configuration changes you made through Multi-Edit?
  • 3.  RE: Sync switch to Aruba Central
    Posted May 19, 2025 03:49 AM
    the switch is 2930M.
    I inherited an infrastructure that I have to manage, some configurations have been modified locally by cli and now they are not synchronized with Aruba Central, how can I solve it?
  • 4.  RE: Sync switch to Aruba Central
    Posted May 19, 2025 04:17 AM
    Locally made changes made on an AOS-S (2930) switches are not synchronized back to Central. All changes must be made in Central
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 5.  RE: Sync switch to Aruba Central
    Posted May 19, 2025 04:31 AM
    is there no way to sync the problem?
  • 6.  RE: Sync switch to Aruba Central
    Posted May 19, 2025 04:35 AM
    Currently not with AOS-S switches. Only with CX switches
    Willem Bargeman
    ACEX #125
  • 7.  RE: Sync switch to Aruba Central
    Posted May 19, 2025 04:39 AM
    Thanks for reply.
  • 8.  RE: Sync switch to Aruba Central
    Posted May 19, 2025 04:50 AM
    ...but if it was an CX switch, will it sync automatically or do you need to actively do something?
  • 9.  RE: Sync switch to Aruba Central
    Posted May 19, 2025 04:54 AM
    for CX switches, there are ways to do it. but the main thing is that if the switch is under Central mgmt, then one needs to use Aruba Central to do the configuration for consistency.  With CX switches, you can use multi-edit option as well.
  • 10.  RE: Sync switch to Aruba Central
    CX switches managed in de UI group can sync configuration changes back to Central. This results in local override which are visible with MultiEdit
    Willem Bargeman
    ACEX #125
