Hello @hemh ,
Logs remains in the switch and stored in logfile.log & Diagfile.log under 'Dir'.
You can check by using below command:
<HPE> dir /all-filesystems -->Can view log files under directory logfile
<HPE>dir /all-filesystems
Directory of flash:
0 -rw- 91373568 Jan 13 2013 00:16:32 5130HI-CMW710-R3507.ipe
1 -rw- 10720256 Aug 08 2008 20:00:00 5130hi-cmw710-boot-r1122p02.bin
2 -rw- 7177216 Jan 13 2013 00:19:14 5130hi-cmw710-boot-r3507.bin
3 -rw- 61771776 Aug 08 2008 20:00:00 5130hi-cmw710-system-r1122p02.bin
4 -rw- 84189184 Jan 13 2013 00:19:54 5130hi-cmw710-system-r3507.bin
5 drw- - Feb 11 2013 00:23:16 diagfile
10 drw- - Jan 09 2014 01:09:35 logfile
<hpe>logfile save -->It will save file into logfile/diagfile directory
<HPE>diagnostic-logfile save
I hope this will help you.
Thanks!
