Community Feedback
  • 1.  system light solid amber
    Posted Apr 24, 2019 03:54 PM
    I have done alot of googling and so far I have not found a fix for the system light being a solid amber on an aruba 325 AP. Any suggestions would be appreciated.
  • 2.  RE: system light solid amber
    Posted Apr 25, 2019 04:17 AM
    Here's the details of the LED indicators on the 320 series APs.
    https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-a00047176en_us&docLocale=en_US
  • 3.  RE: system light solid amber
    Posted Apr 25, 2019 09:14 AM
    All my other 325 aruba AP's are single radio and the USB is disabled but both the system and radio lights are green so I think it has to be something else. Not sure how to find out for sure what the issue is and correct it
  • 4.  RE: system light solid amber
    Posted Apr 25, 2019 09:56 AM
    Are you suggesting that your other APs are powered using PoE 802.3af but not opperating in power-save mode?
    The documentation shows that if operating in power-save mode the system LED will be solid amber. If the AP is operating in monitor mode the radio LED will be solid amber.
  • 5.  RE: system light solid amber
    Posted Apr 25, 2019 10:02 AM
    Well the radio is showing solid green, the AP is configured the same as all the other AP's and they have solid green lights, Is there any other way to tell for sure
  • 6.  RE: system light solid amber
    Posted Apr 25, 2019 10:04 AM
    On the CLI :
    "show ap tech-support ap-name <name of ap> | begin "Power Status"
  • 7.  RE: system light solid amber
    Posted Apr 25, 2019 10:06 AM
    I have been trying to get in the CLI but no one remembers the enable password and I already tried the default admin/admin and can't get in
  • 8.  RE: system light solid amber
    Posted Apr 25, 2019 10:40 AM
    Ok..
    You can get the info from the GUI as well. Diagnostics > Access Points > Technical Support
    Or, you can just find out what PoE standard is powering the AP from the switch it's patched into.
    Or you could sort out your enable password and run the previous command ;)
  • 9.  RE: system light solid amber
    Posted Apr 25, 2019 10:49 AM
    I did a show power for the switch its pulled into
    6 | Yes low usage 17 W 6.5 W Delivering 4 off
  • 10.  RE: system light solid amber
    Posted Apr 25, 2019 10:57 AM
    It is plugged into another switch and it read this
    2/41 | Yes low usage 17 W 0.0 W Searching 0 on
