  • 1.  Table of AP wired uplink port connection speeds, GUI or CLI?
    Posted Nov 07, 2024 11:53 AM
    We are on Aruba 8.10.0.13, as we still have some AP-2xx, though we are in the midst of upgrading them to AP-635.
    Recently, I was looking at a switch for a non-wifi reason, and I noticed that one of our AP-515s in a multigig port showed a connection speed of only 100Mbps. That case happened to be a cable fault, the brown pair was not connected, but it made me look for a table in our MC (nee MM) that shows the wired port speeds of all APs. So far, no success with the GUI, as it does not seem to be a field in the Access Points table. (I may be mis-remembering, as it has been a few years, but I think the Aruba 6 GUI had a column for this?)
    Is there a CLI command to list this? Ideally one that shows all APs, rather than a command that I need to run for each individual AP by name, though I guess either could work.
    Steve Bohrer
    IT Infrastructure, Emerson College
  • 2.  RE: Table of AP wired uplink port connection speeds, GUI or CLI?
    Posted Nov 07, 2024 12:32 PM
    Steve,
    You'll need a list of your AP names (show ap database). Then:
    show ap debug port status ap-name <name>
    at CLI for each AP.
    Brad
  • 3.  RE: Table of AP wired uplink port connection speeds, GUI or CLI?
    Posted Nov 07, 2024 01:16 PM
    Thanks! Looks like the "sh ap debug" commands need to be on the MDs, which makes sense.
    Steve Bohrer
  • 4.  RE: Table of AP wired uplink port connection speeds, GUI or CLI?
    Posted Nov 07, 2024 04:24 PM
    Oy! I found 24 of them, out of about 1300 APs! I'll need to visit them to check for cable issues, I think.
    Steve Bohrer
