  • 1.  TACACS+ Post authentication enforcement
    Posted Sep 12, 2024 11:21 AM
    HI All,
    I am looking for a way to get a HTTP based enforcement onto a TACACS+ service. I can't see why we would not be able to do this, however it is causing me a few issues at the moment.
    Essentially I am looking to trigger an API call on every TACACS+ authentication. This is possible with RADIUS and due to it not effecting the security I would expect this to be possible with TACACS.
    Any thoughts would be great.
    Ben
  • 2.  RE: TACACS+ Post authentication enforcement
    Posted Sep 13, 2024 04:53 AM
    Hi Ben
    Not the answer you are hoping for, but you are not alone in this request.
    There is an active feature request in the Innovation Zone for the feature: https://innovate.arubanetworks.com/ideas/SEC-I-1957
    Log in and vote on the feature request.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 3.  RE: TACACS+ Post authentication enforcement
    Posted Sep 23, 2024 06:15 AM
    Haven't fully tried, but if you have enough information in the authentication request (not the response/roles), you may try to include an HTTP Authorization source under authorization. The config of adding HTTP authorization source to a TACACS+ service seems to be accepted.
