Wired Intelligent Edge
  • 1.  Tag multiple VLANs by role enforcement in Aruba-CX
    Posted Jun 01, 2025 06:11 PM
    Hi Team,
    Locally configured role on Aruba-CX switch for InstantAPs. MAC authentication is enabled on the interface that the APs connect to on the switch. Service configured in ClearPass for AP MAC authentication.
    port-acce role  WIFI-MANAGEMENT
    vlan trunk native  110
    vlan trunk allowed 110,112,120,125
    Role enforcement works fine on switch port [Native VLAN untagged, Allowed VLANs tagged]. The problem is that when trying to connect devices on WiFi, it doesn't work properly. (The AP is not pushing to the correct VLAN -WLAN mapped-  which is tagged on the port)
    But when the switch port is manually configured, the WiFi works fine.
    Are there any limitations to dynamic segmentation and user roles for instant APs on Aruba CX-Switches?
    Reg,
    Shamz
  • 2.  RE: Tag multiple VLANs by role enforcement in Aruba-CX
    Posted Jun 01, 2025 06:55 PM
    so which VLAN does the wifi client gets?
    you can compare your configuration against this technote that covers DUR for IAPs.
    Aruba ClearPass Wired Enforcement for CX switches – Part6
  • 3.  RE: Tag multiple VLANs by role enforcement in Aruba-CX
    Posted Jun 02, 2025 01:11 AM
    Hello ariyap,
    Thanks for your response.
    I thing my problem is that i missed the below command in LUR (as you mentioned in  Aruba ClearPass Wired Enforcement for CX switches – Part3)
    auth-mode device-mode
    Let me test and update
    Reg,
    Shamz
  • 4.  RE: Tag multiple VLANs by role enforcement in Aruba-CX
    Posted Jun 02, 2025 03:44 AM
    Hi
    you can try the below and  change as per your Vlan ID this works for me
    Vlan 10 is PC and Printer
    Vlan 20 is for Phone
    Vlan 1002 is the AP
    _____________________________________________
    port-access lldp-group (AP-lldp-group)
         seq 20 match sys-desc IAP
         seq 21 match sys-desc AP
    port-access role LLDP-AP
        vlan trunk native 1002
        vlan trunk allowed 10,20,1002
    port-access device-profile (AP-lldp-devprofile)
        enable
        associate role LLDP-AP
        associate lldp-group (AP-lldp-group)
    apply the below to all interface
    interface 1/1/13
        no shutdown
        no routing
        qos trust dscp
        loop-protect
  • 5.  RE: Tag multiple VLANs by role enforcement in Aruba-CX
    Posted Jun 11, 2025 01:01 PM
    Hi lw25,
    Thanks for your response and support.
     I added the command  auth-mode device-mode under the role in the switch and the issue has been solved.
    Reg,
    Shamz
