Our speaker Sajin was kind enough to also share the AirMatch troubleshooting commands listed in the webinar- access them below or share the attached document with your teams/ colleagues:
Troubleshooting commands:
Enable debugging:
(ArubaMM) *[mynode] #configure t
Enter Configuration commands, one per line. End with CNTL/Z
(ArubaMM) *[mynode] (config) #logging system level debugging
(ArubaMM) *[mynode] #show log system all | include Air
Dec 14 03:12:26 AirMatch[6258]: <356381> <6258> <DBUG> |AirMatch| Recvd PAPI message buflen 320 msglen 244
Dec 14 03:12:26 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| airmatch_cli_db_dump: Free space in flash : 4191 MB, required space = 3072 MB
Dec 14 03:15:15 AirMatch[6258]: <356381> <6258> <DBUG> |AirMatch| Recvd PAPI message buflen 322 msglen 246
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| MCELL Solver starts ... (Runmode Quick) (switch_ips <>) (deploy_time 1513250116) >>>>>>>>>>>>>> will show the mode, here its airmatch quick mode
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| DB: Taking snapshot ...
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| DB: Loading network site1 ...
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| DB: 374 unique interferes causing 374 interfering nbr_pathloss links
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| DB: Ratio intf/friend = 287/0 = 287.0. Ignoring intf nbrs
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| DB: Raw data: #AP 1 #Radio 2 #Feasibility 2 #Pathloss 0
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| SANITY: Raw data Sanity check ....
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| SANITY: ........ Raw data Sanity check (DONE)
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| Reconstructing the network: site1 5GHz ...
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| ANALYSIS: #RF domains: 1. Sizes 1
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| ANALYSIS: (all:friend:intf) #APs (1:1:0) #Radios (1:1:0) #Ignored intfs: 0
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| ANALYSIS: AP Models: AP-115(1:100.0%)
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| ... Reconstruction (Done)
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| BEFORE: oper network band 5GHz narc 2.0 conflicts 0.0
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| Reconstructing the network: site1 2GHz ...
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| BEFORE: oper network band 2GHz narc 4.0 conflicts 0.0
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| ... Loading DB to Topology (DONE)
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| SIZING: band 5GHz: 1 RF domains Algorithm 14
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| SIZING: band 2GHz: 1 RF domains Algorithm 14
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| PARTITION: ...
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| PARTITION: ... DONE
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| COLORING: band 5GHz: 1 RF domains (Runmode 2)
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| COLORING: ALGO CIR for site1-rfd1-hgh-part0 1 radios 5GHz CBW20
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| COLORING: ALGO CIR for site1-rfd1-hgh-part0 1 radios 5GHz CBW40
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| CBW20 band 5GHz (capacity: 1.0/conflicts: 0.0/narc: 4.0), CBW40 band 5GHz (capacity: 2.0/conflicts: 0.0/narc: 2.0),
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| COLORING: band 2GHz: 1 RF domains (Runmode 2)
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| COLORING: ALGO CIR for site1-rfd1-hgh-part0 1 radios 2GHz CBW20
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| CBW20 band 2GHz (capacity: 1.0/conflicts: 0.0/narc: 4.0),
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| AFTER: solution band 5GHz narc 2.0 conflicts 0.0
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| AFTER: solution band 2GHz narc 4.0 conflicts 0.0
Dec 14 03:15:24 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| ... MCELL Solver (Done)
Dec 14 03:15:34 AirMatch[6258]: <356303> <6258> <DBUG> |AirMatch| CLI CMD PASS: airmatch ap set ap-name AP-115 band 5GHz eirp 21
How to check the airmatch history for an AP?
(ArubaMM) *[mynode] (config) #show airmatch debug history ap-name AP-115
2GHz radio mac 18:64:72:ab:e6:40 ap name AP-115
Time of Change Chan Bandwidth EIRP(dBm) Mode Source
2017-12-14 02:52:13 6-> 11 20-> 20 120-> 12 AP ->AP Solver
2017-12-14 02:51:03 1-> 6 20-> 20 120-> 12 AP ->AP Solver
2017-12-13 05:01:15 1-> 1 20-> 20 120-> 12 AP ->AP Solver
2017-12-12 05:01:17 1-> 1 20-> 20 120-> 12 AP ->AP Solver
2017-12-11 13:01:13 1-> 1 20-> 20 80-> 12 AP ->AP Solver
2017-11-20 13:01:45 1-> 1 20-> 20 9-> 8 AP ->AP Solver
2017-11-19 13:01:46 1-> 1 20-> 20 8-> 9 AP ->AP Solver
2017-11-13 13:01:28 1-> 1 20-> 20 7-> 8 AP ->AP Solver
2017-11-11 13:01:28 1-> 1 20-> 20 8-> 7 AP ->AP Solver
2017-11-09 13:01:19 11-> 1 20-> 20 12-> 8 AP ->AP Solver
2017-11-09 05:01:16 6-> 11 20-> 20 9-> 12 AP ->AP Solver
2017-10-27 05:01:15 6-> 6 20-> 20 25-> 9 AP ->AP Solver
5GHz radio mac 18:64:72:ab:e6:50 ap name AP-115
2017-12-14 02:51:13 44-> 44 40-> 40 210-> 21 AP ->AP Solver
2017-12-14 02:50:03 40-> 44 40-> 40 210-> 21 AP ->AP Solver
2017-12-13 05:00:15 40-> 40 40-> 40 210-> 21 AP ->AP Solver
2017-12-12 05:00:17 40-> 40 40-> 40 210-> 21 AP ->AP Solver
2017-12-11 13:00:13 40-> 40 40-> 40 150-> 21 AP ->AP Solver
2017-11-21 08:31:56 36-> 40 40-> 40 15-> 15 AP ->AP Solver
2017-11-13 13:00:28 36-> 36 40-> 40 16-> 15 AP ->AP Solver
2017-11-12 13:00:28 36-> 36 40-> 40 15-> 16 AP ->AP Solver
2017-11-10 13:00:19 36-> 36 40-> 40 16-> 15 AP ->AP Solver
2017-11-09 13:00:19 64-> 36 40-> 40 21-> 16 AP ->AP Solver
2017-11-09 05:00:16 64-> 64 40-> 40 18-> 21 AP ->AP Solver
2017-10-27 05:00:15 64-> 64 40-> 40 22-> 18 AP ->AP Solver
Checking neighbor information.
(ArubaMM) *[mynode] (config) #show airmatch debug nbr ap-name AP-115 | begin 5GHz
Nbr Mac Is Friend Path Loss(dB) Channel Last Update AP Name
ac:a3:1e:00:a6:90 * 40 60 2017-12-14 02:53:13
84:d4:7e:bd:91:10 * 84 36 2017-12-14 02:53:13
84:d4:7e:d3:61:b0 59 108 2017-12-14 02:53:13
ac:a3:1e:57:48:d0 60 149 2017-12-12 06:17:56
34:fc:b9:2b:10:50 61 161 2017-12-14 02:53:13
18:64:72:a0:73:b0 63 36 2017-12-14 02:53:13
18:64:72:ab:e9:70 63 56 2017-12-14 02:53:13
40:e3:d6:5e:51:f0 63 36 2017-12-14 02:53:13
Check the last optimization:
(ArubaMM) *[mynode] #show airmatch debug optimization last
# 2017-12-14_03:15:16 Quick
# 5GHz network cost/solution cost/improvement: 2/2/0%
# 2.4GHz network cost/solution cost/improvement: 4/4/0%
# Band Radio RFDom Part Chan CBW EIRP(dBm) APName
ID ID
2GHz 18:64:72:ab:e6:40 001 000 6 20 12 AP-115
5GHz 18:64:72:ab:e6:50 001 000 44 40 21 AP-115
[*] regarded frozen | [i] channel ignored because insufficient quality increase
How to check static radios:
(ArubaMM) *[mynode] #show airmatch debug static-radios
How to gather dump:
(ArubaMM) *[mynode] #airmatch db-dump all
db-dump complete. File name is 'airmatch_db_dump.tgz'
(ArubaMM) *[mynode] #dir
-rw-r--r-- 1 root root 74245 Dec 11 04:17 AUDITTRAIL-HISTORY.log
-rw-r--r-- 1 root root 19536 Dec 11 04:17 AUDITTRAIL-LOGIN_OUT-HISTORY.log
-rw-r--r-- 1 root root 2181979 Dec 14 03:12 airmatch_db_dump.tgz >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
drwxr-sr-x 4 root root 4096 Sep 15 06:15 archives
How to check the AP feasibility information:
(ArubaMM) *[mynode] #show airmatch debug feasibility ap-name AP-115
Field Value
Mac 18:64:72:ab:e6:40
Last Update 2017-12-14 03:38:18
Chan 20MHz 1,6,11
Chan 40MHz
Chan 80MHz
Chan 160MHz
Bandwidth 20MHz
Config BW range(MHz) 20 - 20
Hardware BW range(MHz) 20 - 40
EIRP(dBm) 6 - 12
Config EIRP range(dBm) 6 - 12
Hardware EIRP range(dBm) 3 - 25
EIRP Offset(dB) 0
Update Reason Periodic Update
Field Value
Mac 18:64:72:ab:e6:50
Last Update 2017-12-14 03:38:17
Chan 20MHz 36,40,44,48,52,56,60,64,149,153,157,161,165
Chan 40MHz 36,44,52,60,149,157
Chan 80MHz
Chan 160MHz
Bandwidth 20MHz,40MHz
Config BW range(MHz) 20 - 80
EIRP(dBm) 15 - 21
Config EIRP range(dBm) 15 - 21
Hardware EIRP range(dBm) 4 - 22
EIRP Offset(dB) 0
