Wired Intelligent Edge
  • 1.  Tell if 'Allow unsafe upgrades' is required
    Posted Aug 26, 2024 04:30 PM
    Is there a command to display if a VSF pair of switches needs 'unsafe updates'?
    I just upgraded from 10.13.1031 to 10.13.1040 on CX 6300s
    It did not allow me to do an ISSU update.  Is this a possible reason why?
    Attachment(s)
    txt
    6300vsf-upgrade.txt   10 KB 1 version
  • 2.  RE: Tell if 'Allow unsafe upgrades' is required
    Posted Aug 27, 2024 11:30 AM
    you can test it using the following commands:
    show needed-updates next-boot primary
    show needed-updates next-boot secondary
    Best regards,
  • 3.  RE: Tell if 'Allow unsafe upgrades' is required
    Posted May 19, 2025 05:21 AM
    I know this is an old thread, but in case someone finds this and would like an answer, the reason is in the output.
    Stack topology is not a ring. ISSU upgrade aborted
