Cloud Managed Networks
Templates and Variables with Stacked 2930F
  • 1.  Templates and Variables with Stacked 2930F
    Posted Jun 21, 2019 05:34 AM
    Currently having issues with a 4 member stack and templates+variables.
    The template/configuration shows in the audit trail as good but if i try to use a condition statement for a variable that is assigned to member 2/3/4 it fails to apply ( but still says its good ).
    Example
    Member 2 JSON variables
    "vsf.member": "2",
    "if.2_1.name": "NOT IN USE",
    "if.2_1.poe": "1",
    "if.2_1.state": "1",
    "if.2_1.stpedge": "1",
    "if.2_1.stpfilter": "",
    "if.2_1.stpguard": "1",
    Template Condition
    %if vsf.member=2%
    %if if.2_1.stpedge=1%
    spanning-tree 2/1 admin-edge-port
    %endif%
    %endif%
    If i add the Template Condition line "spanning-tree 2/1 admin-edge-port" under any condition statement for member 1 it applies the configuration.
    %if vsf.member=1%
    %if if.1_1.stpedge=1%
    spanning-tree 1/1 admin-edge-port
    %endif%
    %endif%
    Is this by design or a bug?
    I would of thought assigning member variables to allow flexibility/scalability was the idea of templates?
    If i am doing this wrong could someone point me in the right direction
