I have created a custom adapter for backing up a third party device.
Currently stuck at "Failed to Execute Script"
I can log in ok via IMC Telnet proxy but when I try the backup config there is no telnet activity in wireshark.
The backup log shows:
2019-01-18 10:58:54.896 [INFO (0)] [THREAD(10748)] [imcscriptttol] log: =============================== Begin=============================
2019-01-18 10:58:53.629 [INFO (0)] [THREAD(11988)] [qvdm::QvGetLogFileSize] get file size from qvdm.conf: 50
2019-01-18 10:58:53.630 [INFO (0)] [THREAD(11988)] [ScriptTool::execScriptAction()] component_name: ICC, service_name: ConfigBackup, action_name: backup_running_config, input_vars: DevName=Phybridge_SW3?_?TFTPFile=running_2593189442.cfg?_?TFTPServer=10.10.10.10?_?UnitList=?_?VpnName=
2019-01-18 10:58:53.652 [INFO (2001)] [THREAD(11988)] [CCLIScriptProcessor::init()] Device login type is 1,dev_id=4054,AdaptName=PhybridgePOLRE
2019-01-18 10:58:53.653 [INFO (0)] [THREAD(11988)] [imcdm::base64_decode_string()] length of param is: 512
2019-01-18 10:58:53.654 [INFO (0)] [THREAD(11988)] [imcdm::base64_decode_string()] length of param is: 20480
2019-01-18 10:58:53.654 [INFO (-100)] [THREAD(11988)] [CSSHScriptProcessor::init()] Fail to call CSysPara::getPara() to get ssh_client.AdaptName=PhybridgePOLRE
2019-01-18 10:58:53.655 [INFO (-100)] [THREAD(11988)] [CSSHScriptProcessor::init()] Fail to call CSysPara::getPara() to get sftp_client.AdaptName=PhybridgePOLRE
2019-01-18 10:58:53.655 [WARNING (0)] [THREAD(11988)] [CQvDBReaderADP::~CQvDBReaderADP] Cancel current SQL when data have not be fetched out.
2019-01-18 10:58:53.655 [INFO (0)] [THREAD(11988)] [CComponentAdapter::parseVendorAdapter()] Begin to parse ...
2019-01-18 10:58:53.656 [INFO (0)] [THREAD(11988)] [CComponentAdapter::parseVendorAdapter()] Finished to parse!
2019-01-18 10:58:53.860 [INFO (0)] [THREAD(11988)] [CCLIScriptProcessor::login_impl()] Begin ...
2019-01-18 10:58:53.860 [INFO (0)] [THREAD(11988)] [CCLIScriptProcessor::login()] Begin ...
2019-01-18 10:58:53.860 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Begin to exec: spawn plink -telnet 1.2.3.4
2019-01-18 10:58:53.866 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Finished.
2019-01-18 10:58:53.866 [INFO (0)] [THREAD(11988)] [CTelnetScriptProcessor::gotoMode()] Begin, ip: 1.2.3.4, current mode: connect, new mode: initialize
2019-01-18 10:58:53.866 [INFO (0)] [THREAD(11988)] [CTelnetScriptProcessor::gotoMode()] Begin, ip: 1.2.3.4, current mode: connect, new mode: exec
2019-01-18 10:58:53.867 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Begin to exec: C:/Program Files/iMC/server/bin/../../server/conf/adapters/ICC/U.C.Davis ECE Depts/PhybridgePOLRE/initialize.tcl
2019-01-18 10:58:53.870 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Finished.
2019-01-18 10:58:53.870 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Begin to exec: C:/Program Files/iMC/server/bin/../../server/conf/adapters/ICC/U.C.Davis ECE Depts/PhybridgePOLRE/enter_exec.tcl
2019-01-18 10:58:53.874 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Finished.
2019-01-18 10:58:53.874 [INFO (0)] [THREAD(11988)] [CCLIScriptProcessor::login()] End.
2019-01-18 10:58:53.874 [INFO (0)] [THREAD(11988)] [CTelnetScriptProcessor::gotoMode()] Begin, ip: 1.2.3.4, current mode: exec, new mode: exec
2019-01-18 10:58:53.874 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Begin to exec: C:/Program Files/iMC/server/bin/../../server/conf/adapters/ICC/U.C.Davis ECE Depts/PhybridgePOLRE/backup_running_config_tftp.tcl
2019-01-18 10:58:53.878 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Finished.
2019-01-18 10:58:53.878 [INFO (0)] [THREAD(11988)] [CTelnetScriptProcessor::logout()] Begin, DevIP = 1.2.3.4
2019-01-18 10:58:53.878 [INFO (0)] [THREAD(11988)] [CTelnetScriptProcessor::gotoMode()] Begin, ip: 1.2.3.4, current mode: exec, new mode:
2019-01-18 10:58:53.878 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Begin to exec: C:/Program Files/iMC/server/bin/../../server/conf/adapters/ICC/U.C.Davis ECE Depts/PhybridgePOLRE/exit_exec.tcl
2019-01-18 10:58:53.882 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Finished.
2019-01-18 10:58:53.882 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Begin to exec: close
2019-01-18 10:58:53.884 [INFO (0)] [THREAD(11988)] [CTclExecutor::exec_impl()] Finished.
2019-01-18 10:58:53.884 [INFO (0)] [THREAD(11988)] [CTelnetScriptProcessor::logout()] End.
2019-01-18 10:58:54.896 [INFO (0)] [THREAD(10748)] [imcscriptttol] log: =============================== End===============================
The scriptool file is deleted from the server/tmp folder so I am unable to view it.
The device itself records 3 login attempts, so not sure how this is happening as device only supports telnet and wireshark shows no telnet activity. I have removed SNMP write.
