  • 1.  to many legacy clients on radio
    Posted Sep 10, 2013 08:24 PM
    We been seeing this message in Airwave 7.7 and was wondering if anyone else has seen this and if you have an interpretation what this indicator is suggesting.  The indicator below was reported from an AP225 but we've also seen this on other AP's.  I know there are not 8 legacy clients on this radio.  Anyone have any insight?
    Indicator
    Value
    Ideal
    Too Many Legacy Clients On Radio
    8
    ≤ 3
  • 2.  RE: to many legacy clients on radio
    Posted Sep 10, 2013 08:56 PM
    When looking at that AP's monitor page (before the radio page), use the funnel filter on the connection column to see what kinds of connections are present, and then sort by interface to get all clients on the radio you're focusing on grouped together.
    Clients connecting at an 802.11a / 802.11b rate are considered legacy clients.  Any client connecting on less than 802.11n are considered legacy clients.
  • 3.  RE: to many legacy clients on radio
    Posted Jan 22, 2016 09:50 AM
    We are having similar issues and had opened a TAC case.
    Would be interested to know how did you solve this situation or if anyone has any advise from their own experience.
    DSP
  • 4.  RE: to many legacy clients on radio
    Posted Jan 22, 2016 09:52 AM
    DSP,
    That trigger in Airwave is fairly arbitrary.  It does not automatically guarantee problems, but it lets you know that you have legacy clients on an points that exceeds a threshold.
  • 5.  RE: to many legacy clients on radio
    Posted Jan 22, 2016 10:37 AM
    Hello Cjoseph, and thanks for your reply.
    The problem we are having is that after few weeks working normally and while clients are able to get IP@, and complete authentication the AP stops forwarding traffic on any of the SSIDs.
    What I would like to understand is what is triggering this condition the AP runs into after sometime like if there were a memory leak condition met ...
    AP is a 225 and I would expect it to be able to manage 38 connections even if there are legacy devices. The AP is deployed in a HD area.
    Too Many Total Clients Diagnostics
    Indicator
    Value
    38
    Ideal
    ≤20
    Explanation
    The total number of wireless clients currently associated to this AP. Too many clients on an AP can strain CPU and memory resources.
    Resolution
    ARM should load balance. Sustained high rates will require adding capacity or more APs.
    Anywhoo will wait an see what does TAC investigations lead us, I just found these entries on the AP TS:
    <2>[21594.150173] kernel BUG at drivers/net/gianfar.c:2912!
    <4>[21594.210601] Oops: Exception in kernel mode, sig: 5 [#1]
    And I am concern behind these warning of too many clients on radio we may be facing an DoS attack :
    In January 19th 2016 a vulnerability was discovered in the Linux kernel. This vulnerability could allowed a regular user to escalate privileges.
    Red Hat has been made aware of a vulnerability affecting the kernel that ships with Red Hat Enterprise Linux 7 kernel and derivatives. CVE-2016-0728 documents and exploit that could allow a skilled attacker to execute arbitrary code and also be used to escalate their privileges on the system. The attacker must be able to run custom code on the account; in the most common configuration, this requires them to have a login and shell account on the target system.
    DSP
  • 6.  RE: to many legacy clients on radio
    Posted Jan 22, 2016 03:56 PM
    Please allow TAC to take a look at your tech support in your controller to find out what your next move should be.  That is the best option, here.
