I received the following message in Airwave: Too Many Clients on Radio. Airwave suggests that too many clients are concurrently connected to the same radio which results in reduced capacity.
The Airwave threshold is set to <10. Currently, the AP shows 17 clients connected on the radio.
Airwave resolution indicates that ARM shoudl be load balanced from AP to AP and across bands.
--- ARM should load balance from AP to AP and across bands. Sustained high rates will require adding capacity or more APs --
Are there different ARM configurations between the AP225 and AP135s? I have 3400 Series Controllers running the same config/OS(6.4.1.0) at different office locations. However, this is the only site enabled with Aruba 225 Series APs.
Are there different ARM configs required for the 225 Series APs that differ than AP135 that address this 'Too Many Clients on Radio' issue?
#AP225#3400
