You could contact support, absolutely. Ultimately, you might want to turn off the Alert if it is not accompanied by actionable consequences: AP Alerts
Original Message:
Sent: Oct 04, 2023 08:25 AM
Subject: too much Radio frames retry with AOS10 and Central
Hi Colin,
customer is not reporting any client issues. Which next troubleshooting steps do you suggest?
Customer can see Alarms and he's getting nervous.
Should I contact support team?
Cheers Mic
Original Message:
Sent: Oct 04, 2023 06:59 AM
Question:
Do you have any issues with client performance? The retries message could be erroneous (few frames generating a large percentage of retries).
Original Message:
Sent: Oct 04, 2023 06:52 AM
Hi Rob,
thx for your information.
Environment is "normal density" with around 15-20m distance between APs. No high amount of neigbors with autonom WiFi.
I can see the problem at a lot of different APs :
I changed Channel Width to 20 / 40MHz - so no more 80 MHz.
Here you can see WiFi Power range:
I though that central is managing WiFI Setup with auto-power and auto-channel automatically!
Cheers
Michael
PS: I will check interference with Ekahau Tool.
Original Message:
Sent: Oct 03, 2023 09:05 AM
Is this on specific APs? Or on all APs?
In what type of environments are these APs deployed? Is it high density? Or in a place with many neighbors that have WiFi deployed?
Could it be that there is a lot of RF interference in this place?
You may use spectrum analysis tools (external or built in to the AP) to get a better understanding of your RF Environment.
Original Message:
Sent: Sep 28, 2023 03:02 AM
Hello Community,
we are managing more than 100 APs with Aruba Central (EU Cloud) and got al lot of Alarms with message:
"Radio frames retry percent on 5 (also 2.4 GHz) Channel 60E has been above 90% for about 15 minutes since 2023-09-27 12:14:02 UTC on AP xyz"
APs are running AOS 10 (10.4.0.2) and we are using Auto Power and Auto Channel.
Please can someone explain what could be the reason for this?
What is the best way to troubleshoot this issue?
Cheers Michael
