Network Management
  • 1.  Topology Map links
    Posted May 03, 2016 05:11 AM
    Hi all...
    Is it possible to keep inactive links present on the topology map, after they have been disconnected.
    We have a hugh STP ring on ring topology, and when a fiber link goes down, it's easier for operations to look at the topology map to see where the issue is.
    Michael
  • 2.  RE: Topology Map links
    Posted May 04, 2016 08:45 PM
    these settings might possibly help you:
    System > System Settings > Layer 2 Topology Configuration (midway down the page)
  • 3.  RE: Topology Map links
    Posted May 12, 2016 11:11 AM
    I have the same question.
    How to display the blocked ports by STP innetwork topology.
  • 4.  RE: Topology Map links
    Posted May 13, 2016 10:06 AM
    If there is a "loop" usually iMC draws a little circle at the top of the switch icon - get rid of the loop/block and the icon changes (after a sync).  I'd also be interesed how to alert on this instead though...
