I checked, and could find just one support case where the customer got the hardware replaced. Does not look like something you can fix yourself. It looks like the flash is corrupted in some way.
What you may try is to upgrade from the cpboot to the
latest firmware version, and see if that resolves something.
Edit: Note that the S1500 has been end-of-life for quite some time. It may not be recommended to deploy these devices in production as the software may contain security vulnerabilities and TAC Support is unlikely to be able to assist you in case of problems.
Original Message:
Sent: Jul 26, 2022 06:47 AM
Subject: TPM issue on S1500-12P
Hi All,
There are serveral S1500-12P in the lab, which got the same following error on the console.
The switches seems got bricked, is there anyway to bring them back?
Aruba NetworksArubaOS Version 7.4.0.2 (build 48818 / label #48818) Built by p4build@port-royal on 2015-02-27 at 10:04:19 PST (gcc version 3.4.3)Copyright (c) 2002-2015, Aruba Networks, Inc.Inventory uninitialized - setting up empty inventory: Bad magic number <<<<< Welcome to Aruba Networks - Aruba S1500-12P >>>>>Performing CompactFlash fast test... Checking for file system...Passed.Reboot Cause: Hard Watchdog reset (0xee:0xee:0xcab3)Initializing TPM and CertificatesTPM and Certificate Initialization successful.PoE firmware [Ok]Inventory uninitialized - setting up empty inventory: Bad magic numberCouldn't identify the role .. Enabling local console
