Comware
  • 1.  Transceiver Compatibility with FlexFabric 5945
    Posted Sep 30, 2024 11:00 AM
    We are using H3C-SFP-10G-T-SO modules (either from FS or SolidOptics). These connectors are natively recognized and work properly in the FF5940. However, to make the connectors functional in the FF5945, I need to configure the interface as follows:
    [SW-FF5945-Ten-GigabitEthernet1/1/8] port up-mode
    Is this normal? Is this the correct procedure on the FF5945 to make the transceiver functional?
    Thank you.
    Spec.
  • 2.  RE: Transceiver Compatibility with FlexFabric 5945
    Posted Oct 01, 2024 03:47 AM
    RJ45 10G transceivers are not supported on 5945. If you have 1G variant, make sure that is it compatible with JD089B transceiver like https://edgeoptic.com/products/hp/jd089b/.
    You can find transceiver guides in networkingsupport.hpe.com portal. For 10G SFPs here is the link to the guide.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 3.  RE: Transceiver Compatibility with FlexFabric 5945
    Posted Oct 07, 2024 09:33 AM
    I confirm that the transceiver models are defined as compatible.
    During the test I performed on our FlexFabric 5945, the transceiver works properly when we force the port into 'up-mode.'
    However, since I'm not certain if this behavior is normal, I prefer to refrain from using these transceivers on our FlexFabric 5945.
