Aruba Central
Transferring From Aruba Central To Mobility Controller
  • 1.  Transferring From Aruba Central To Mobility Controller
    Posted Jan 07, 2023 02:56 AM
    My organization is currently using aruba central to manage AP, switch and gateway.
    They would like to consider using mobility controller to reduce use.
    I know aruba central needs a license but does mobility controller need one and is it cheaper?
    How to transfer devices being managed by aruba central to mobility controller?
  • 2.  RE: Transferring From Aruba Central To Mobility Controller
    Posted Jan 09, 2023 03:45 AM
    It may be best to work with your Aruba Partner to discuss the options. The most logical option would be to implement AOS 10 with Central, and in that case a controller (or gateway is the new name in AOS 10, but it's the same component) would have a subscription in Central but no other licenses. But there are more options, so best to work with your partner to pick the best one.
