Trial key license for CP-VA-5k
aboj
abojApr 13, 2017 12:44 PM
aboj
  • 1.  Trial key license for CP-VA-5k
    Posted Apr 13, 2017 02:39 AM
    Is there a trial key license I can use to activate a 5k system until I have the final code ?
  • 2.  RE: Trial key license for CP-VA-5k
    Posted Apr 13, 2017 03:11 AM
    You can request an eval key via MyNetworking Portal (https://www.hpe.com/networking/mynetworking), or contact your local Aruba partner or Aruba SE.
    When registered and login go to register license and select a ClearPass 90-day eval (Lic-1-ClearPass). That should run for 90 days, and you can replace the key and subscription id when you have your production license.
    Make sure you select the CP-VA-5K when deploying your VM.
  • 3.  RE: Trial key license for CP-VA-5k
    Posted Apr 13, 2017 09:09 AM
    Thank you, this is very helpful and allow me to more forward with the expansion on my cluster
  • 4.  RE: Trial key license for CP-VA-5k
  • 5.  RE: Trial key license for CP-VA-5k
    Posted Apr 13, 2017 09:52 AM
    I've installed two trial licenses on two 5k and they are showing 500 endpoint. Will this be an issue when I install the permanent 5k key ?
  • 6.  RE: Trial key license for CP-VA-5k
    Posted Apr 13, 2017 10:41 AM
    If the platform is deployed as 5K during installation, I don't expect any issues. That license shows only 500 is no problem and should change when you change the license to you production key.
  • 7.  RE: Trial key license for CP-VA-5k
    Posted May 31, 2017 06:14 AM
    As a follow up and to close the loop. I've installed the permanent licenses on the trial nodes and the numbers of licenses have been updated accordingly.
    Thanks!
  • 8.  RE: Trial key license for CP-VA-5k
    Posted Apr 13, 2017 12:44 PM
    Thank you for the details !
  • 9.  RE: Trial key license for CP-VA-5k
    Posted Apr 19, 2017 09:22 PM
    Sifus,
    I'm using CP-SW-EVAL with the sizing of CP-5K and already have my production license activated. is there any issue if i continue using  CP-SW-EVAL? I dont want to do the morph because it asked me to add in another hard disk...
  • 10.  RE: Trial key license for CP-VA-5k
    Posted Apr 19, 2017 09:44 PM
    You need to use the correct specs for a 5K or it will not be supported.
  • 11.  RE: Trial key license for CP-VA-5k
    Posted Apr 19, 2017 09:47 PM
    yes we are following the requirment in the guideline. it just that using cp eval..right now using 2 hard disk with 20 GB and 1 TB..can we keep on using eval but with the spec of 5 K?
  • 12.  RE: Trial key license for CP-VA-5k
    Posted Apr 19, 2017 09:49 PM
    You should morph the VM.
  • 13.  RE: Trial key license for CP-VA-5k
    Posted Apr 19, 2017 09:50 PM
    any long term effect if we didnt morph it?
  • 14.  RE: Trial key license for CP-VA-5k
    Posted Apr 19, 2017 09:55 PM
    TAC support
  • 15.  RE: Trial key license for CP-VA-5k
    Posted Apr 19, 2017 10:02 PM
    one last thing..if we morph it..and ask to add in another scsi 0:2..what is the recommended size...1 TB also?
  • 16.  RE: Trial key license for CP-VA-5k
    Posted Apr 19, 2017 10:03 PM
    Please work with TAC on this if it’s a live environment.
  • 17.  RE: Trial key license for CP-VA-5k
