Wired Intelligent Edge
  • 1.  Trunk plus untagged ?
    Posted Apr 11, 2024 07:43 AM
    Hi
    ArubaOS-CX 8360 Version  LL.10.10.1090
    I was asked to config one port as trunk for some vlans and access to a certain vlan ( not vlan 1 ) .
    Can't find anything equivalent to the " tagged + untagged " that is available on older HP switches
  • 2.  RE: Trunk plus untagged ?
    Posted Apr 11, 2024 08:21 AM
    Assuming you have vlans 10, 20, 30, and that you want 10 as your untagged vlan:
    vlan trunk native 10
    vlan trunk allowed 10,20,30
  • 3.  RE: Trunk plus untagged ?
    Posted Apr 14, 2024 01:19 AM
    That's what I thought,
    just worried that BPDUs will enter a VLAN that is not the NATIVE one in the rest of the environment.
    In procurve the setting was on the vlan and not on the port so it was more convenient to play with the untagged and the tagged.
