Comware
  • 1.  Tunnel GRE HP 5500 JD377A
    Posted Oct 01, 2018 10:27 AM
    Bonjour,
    J'aimerais monter un tunnel GRE avec un HP 5500 EI (j'ai un CISCO en face) mais visiblement soit ce n'est pas possible, soit l'os ne le permet pas.
    Existe t-il un os compatible GRE pour les 5500 EI ?
    Merci d'avance de votre réponse.
    Cordialement.
    Google Translated
    I would like to mount a GRE tunnel with an HP 5500 EI (I have a CISCO in front) but obviously it is not possible, or the bone does not allow it.
    Is there a GRE compatible bone for the 5500 EI?
    Thank you in advance for your response.
    Cordially.
  • 2.  RE: Tunnel GRE HP 5500 JD377A
    Posted Oct 09, 2018 03:11 PM
    Dear Customer,
    Not sure, did I understand your query here. Or to be specific, when you say "Is there a GRE compatible bone for the 5500 EI?" What does the bone refers here?
    But you may check the below link for GRE Tunnel Configuration steps on the Comware switches.
    https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c03539345
    If the above information alleviates your query, dont forget to give Kudos!
  • 3.  RE: Tunnel GRE HP 5500 JD377A
    Posted Oct 10, 2018 12:13 AM
    May be he refers, Network Backbone or Backbone router whcih is compatible with HP 5500 JD377A , Just a thought.....
