Looking at a design where we are using Aruba Switches configured for UBT and DUR and Controllers to Terminate Tunneled Node we typically have the switch DUR with the Secondary Role to use on the controller. With this configuration, the Controller needs to have a locally defined User Role that matches the Secondary Role passed to it.
I want to continue to make configurations as dynamic as possible. In other deployments, such as a Wireless Controller deployment, we can configure AAA to Download User Role from Clearpass. This eases the Administrative overhead needed from the customers perspective so they can create all Roles in Clearpass and not require them to be created on the Controller (another touch point).
Anyone know if it is possible to somehow use UBT and Tunneled Node with or without a Secondary User role and instead have the controller Download the role from Clearpass? They only way I can see this working is if the AAA profile forced the user/device to perform a secondary authentication to trigger the controller DUR... which would likely cause issues.
This would be great especially in deployment where a customer is using Controllers and Clearpass for Wired and Wireless authentication. We now just define a single User Role that fits both! Pipe dream for now I think.
