Cloud Managed Networks
  • 1.  [TUTORIAL] Aruba AOS10 AP and Gateway Solution
    Posted Jan 07, 2024 11:32 PM
    This is a 4x parts AOS10.4 tutorial series. The aim here is to provide the starting point to put together a solution that include the AOS10 APs, two gateways, ClearPass and obviously Aruba Central.
    Part1  covers the configuration for
    • Aruba Central AP group
    • Aruba Central gateway group
    • ClearPass
    Part2  covers the WLAN configuration and testing for
    • Tunnelled Mode
    • Bridge Mode
    • Mixed Mode
    Part3 covers the WLAN configuration and testing for
    • Guest WLAN in Tunnelled Mode
    • Corresponding ClearPass configuration
    Part 4 covers the WLAN configuration and testing for
    • Guest WLAN in Bridge Mode
    Hope you'll find it useful and as always please send through your feedback for improvement.
  • 2.  RE: [TUTORIAL] Aruba AOS10 AP and Gateway Solution
    Posted Jan 11, 2024 06:07 PM
    Hi ariyap
    awesome work on this guide thanks
    I am migrating  a existing infrastruture from on-prem to cloud and its working already with clearpass, one controller already as a GW on Central👍.
    I only have an issue with redirect page on guest. In this example google, but is going to be company site
    just a dought. Does guest vlan on gateway needs to have IP?
    After getting ip ,  putting username and pass on guest captive portal, we receive an error:
    Error resolving "www.google.pt": Temporary failure in name resolution
    what could be?
  • 3.  RE: [TUTORIAL] Aruba AOS10 AP and Gateway Solution
    Posted Jan 11, 2024 07:37 PM
    if your AOS10 APs for guest WLANs are in tunnel mode than for sure you need the gateways to have an IP address on the guest VLAN
    are you using ClearPass for your guest captive portal and authentication?
  • 4.  RE: [TUTORIAL] Aruba AOS10 AP and Gateway Solution
    Posted Jan 12, 2024 11:05 AM
    Hi
    Yes, we are using Clearpass.
    We had an infrastruture on prem ( MM and MC) and Clearpass
    Now we already migrate 1 of the controllers to Central and some AP´s are already working in Central also, with CLlearpass also integrated
    Corporate SSID and guest also working, but that error on guest captive portal
    Since I used the same configuration , the only difference is that, on the gateway migrated to Central, i did not put IP address under the guest vlan, so it should be necessary.
    In the old on prem implementation we had a the guest vlan with interface IP
    Regards
