Cloud Managed Networks
[TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
This thread has been viewed 746 times
  • 1.  [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Nov 24, 2024 08:22 PM
    Edited by ariyap Jan 08, 2025 05:39 PM
    Personal Wireless Networks (PWN) are groups of user-owned Wi-Fi devices that connect and operate together in a VLAN, enabling communication within that network. It's essential to ensure that only devices within the designated group can interact in one another, along with an added ability for the device owners to permit Multicast DNS (mDNS) and Simple Service Discovery Protocol (SSDP) based services to be shared with their friends.
    I'll be demonstrating PWN solution In this technote "Personal Wireless Network with Aruba Central Cloud Auth – Admin Managed" using Multi Pre-Shared Key (MPSK) on AOS10 APs and Cloud Auth to provide user role-based policies for segmentation without any dependency on an identity store.
    Hope you'll find it useful and as always please send through your feedback for improvement.
  • 2.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Nov 25, 2024 10:04 AM
    This looks like a feature I'd love to implement on our network.  Reading your tutorial, though, it creates the MPSK SSID in bridge mode.  Our MPSK SSID is in tunnel mode and I don't see the Personal Wireless Network option when I look at our MPSK SSID.  I assume that means bridge mode is currently a requirement.  Will support be added for tunnel mode MPSK SSIDs in the future?
  • 3.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Nov 25, 2024 05:46 PM
    Yes at this stage bridged forwarding is the requirement. Like always new features/enhancement will be done in phases.
    For details you can contact your local HPE Aruba SE.
  • 4.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Dec 02, 2024 09:19 AM
    Works perfectly, thank you for the great tutorial!
    How did you get the 'Password Portal' links under MPSK Management?
    Greez,
    Uli
  • 5.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Dec 02, 2024 02:01 PM
  • 6.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Dec 03, 2024 03:27 AM
    Edited by upsisworld Dec 03, 2024 03:28 AM
    Hi Herman,
    this screenshot also was included in @ariyap`s document and is the reason for my question.
    In my case it looks like that:
    No 'Open' nor 'Copy URL' visible ...
    Greez,
    Uli
  • 7.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Dec 09, 2024 05:53 AM
    Did you connect your Identity Provider? I tested and if there is no Identity Provider configured (Entra ID, Google Workspace, Okta), the URL is not shown (because the users can't login); once I added the provider, the URL link shows up.
  • 8.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Dec 09, 2024 09:33 AM
    Thanks a lot, that was the part I was missing!
    Greez,
    Uli
  • 9.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Dec 11, 2024 05:42 AM
    Hi, last week I experimented a bit with Central MPSK-based Personal Wireless Network, which was exceptionally easy and worked well. At the time I was only using admin-managed named MPSKs.
    Yesterday evening I also set up Entra ID as an IDP. This morning, MPSKs created via the Entra ID-authenticated portal also worked. At some point, however, I noticed that the test clients were going in and out of the SSID every second, regardless of whether they were admin-managed or via the portal.
     I see the following message in the events on Central:
    "Onboarding failed for client 3e:9c:29:xx:xx:xx in Deauthentication/Disassociation phase to BSSID 94:64:24:yy:yy:yy on channel 100+ of AP hostname AP-635. Reason: Previous authentication is not valid"
    Unfortunately, deleting the Entra ID connection (the only change to the overall construct) did not fix it! All other SSIDs (1x, PSK and Cloudguest) work without drama.
    Do you have any idea what is going wrong here?
    Greez,
    Uli
  • 10.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Dec 11, 2024 07:56 AM
    Could it be that your AP clock is not syncronized? Otherwise, I would open a TAC case to let them find out what is going on here. Looks like the AP invalidates the authentication, which is not expeced.
  • 11.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Dec 11, 2024 11:35 AM
    Herman,
    Thank you for the hint, but the clock is synchronized.
    As this was just an experiment in my lab I do not want to keep TAC busy with that. I will rebuild it sometime and see how it works.
    Greez,
    Uli
  • 12.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Feb 19, 2025 02:28 AM
    @ariyap is there any way we could enforce PAN IDs via our own external RADIUS sever with some custom RADIUS VSAs?
    Our solution is integrated with the Aruba Unbound MPSK technology, so we perform key matching on scale on our system, and the ability to enforce PAN without VLANs would be a killer application for our hospitality offering.
    Here the docs for reference:
    https://docs.cusna.io/wifi-integration/summary-of-supported-wifi-vendors/aruba-unbound-mpsk
  • 13.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Feb 19, 2025 02:32 AM
    Assuming you are an HPE Technology Partner, this is something your would reach out for with your Partner Alliance Manager or partner contact in HPE.
  • 14.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Feb 19, 2025 04:52 AM
    yes that is a good use case. As Herman mentioned it is best to reach out to Partner Alliance Manager or to your Local HPE Aruba contact to put you in touch with them.
  • 15.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Feb 20, 2025 02:58 AM
    Hi @upsisworld
    You can return PAN ID via Aruba-PAN-Id TLV radius attribute. It's 32 bit integer value with specific structure.  Look for Personal Wireless Networks presentations from Bob Filer, Kevin Marshal, Diego Fontes for HPE Tech Jam 2024 for more details on the structure of attribute.
     Best, Gorazd
  • 16.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Feb 24, 2025 11:53 AM
    Thanks @Gorazd Kikelj this is very helpful and it should be enough.
    I cannot find anywhere the presentation you mentioned form Bob Filer, Kevin Marshal, Diego Fontes. Any chance you can point me to the right direction?
  • 17.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Feb 25, 2025 12:14 AM
    Hi @IvanMuccini.
    You can find presentation on HPE Tech Pro  under Events / Tech Jam Vienna ARU177BRO_V or Tech Jam Atlanta ARU177BRO_A
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 18.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Feb 25, 2025 06:11 AM
    Please note that this is not public information. Access requires a partner agreement to be in place, and it may even be only for attendees of the Tech Jam event (not sure, not checked). If you are part of the Technology Partner ecosystem, you should be able to get access to such information.
  • 19.  RE: [TUTORIAL] Personal Wireless Network with Aruba Central and AOS10
    Posted Feb 25, 2025 06:18 AM
    Presentations are available on psnow. With standard partner access you should be able to access presentations.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
