Wired Intelligent Edge
  • 1.  Two New Buildings Using Aruba CX 8320 VSX Pairs
    Posted Jan 10, 2020 06:48 PM
    Edited by bygrob77 Nov 12, 2021 03:16 AM
    fgewqqfasdgxc
  • 2.  RE: Two New Buildings Using Aruba CX 8320 VSX Pairs
    Posted Jan 10, 2020 11:25 PM
    Nevermind, got it..
    __________________________________________________________________
    What was the reason to choose 2930Fs that sits between Meraki MX and 8320s?
  • 3.  RE: Two New Buildings Using Aruba CX 8320 VSX Pairs
    Posted Jan 12, 2020 11:15 AM
    Hi!
    I have a question: what is the reason for using Aruba 2930F 48G (VSF) as Core? ...I mean...I hope that design wasn't somewhat forced/limited by Cisco Meraki interfaces types (e.g. 1G fixed Ethernet versus SFP+)
  • 4.  RE: Two New Buildings Using Aruba CX 8320 VSX Pairs
    Posted Jan 13, 2020 09:37 AM
    Hi, thanks for your question and I do hope my response answers your
    question, but if you still have doubt or thoughts, please share them with
    me.
    The idea with buying the 8320's was to distribute very long range IDF's in
    a very large warehouse and our intent was also to make them the core. But
    when the time came, we discovered that the 8320 do not become a single
    switch like we thought. We initially configured active gateway's alongside
    a transient VLAN which required two different IP's. From the
    Meraki's perspective we couldn't add two routes (two different) IP's for
    the same subnet; should one of the 8320's go down. Another factor was that
    the MX 83's do not have SPF+. They do have SFP (1g) which we are using to
    the 8320's.
    The 2930F's are in VSF and act as one switch which means the pair have one
    IP addresses configured for the transient vLAN. If one member goes
    offline, everything still routes and HA kicks off on the Meraki with just a
    single timeout and flow continues to work. We also need the 2930's for
    other 1G Copper devices like NetBoxf for the rack, NVR, MPLS handoff,
    Broadband handoff, Integrated Lights Out, Management, and many more. Thing
    would be very different had we purchased MX250 which has SFP+ ports, but
    the cost was not worth the reward. If this was a site full of users and
    workstations, then we would have considered that route.
    For now, the Meraki's are connected via SFP (1G) to the 8320 which do down
    convert to 1GB and in those links we are presently using VLAN1 which will
    change to a NATIVE vLAN. Then we have three copper links (WiFi, Guest WiFi
    and IOT). The Meraki is the core for these three networks because we have
    much more control with security\zones\silo's. We are using ACL's for the
    other networks running off 2930's. Which are very few, under 8 total
    vLAN's\Subnets.
  • 5.  RE: Two New Buildings Using Aruba CX 8320 VSX Pairs
    Posted Jan 15, 2020 04:16 PM
    Gosh...pretty sure I read Meraki MX86 and/or MX84...not MX83...by the way...let me take some time to read all you wrote (the why and what)...initially, when I saw the VSF positioning you decided, the first concern I had was "He is going to have troubles when doing a VSF update...for sure he will need a proper maintenance window during which the entire VSF will be down...". With a VSX as Core such concern simply doesn't exist...so let me check if I understood exactly why your Meraki implementation (physical interfaces apart) would not fit the case of a VSX as Core.
  • 6.  RE: Two New Buildings Using Aruba CX 8320 VSX Pairs
    Posted Jan 13, 2020 12:08 PM
    Edited by bygrob77 Nov 12, 2021 03:17 AM
    iuterytwerwed
