Become a Member
Hi Guys,
I have to questions :) ( I just want to be sure)
Please advise,
Thanks in advance,
Me
With Instant you can either add each physical IP of each IAP as RADIUS clients, or enable Dynamic RADIUS Proxy; by which all IAPs will use the VC IP. You have to have a satic VC IP defined for this to work.
OK Thanks :)
So i use virtual controller ip option + radius proxy - then i will only need to add the virtual controller ip to the raidus as nas-ip
i understood right?
Exactly. Single NAS Client on RADIUS; all IAPs in cluster will use the static VC address as the NAS IP.
Thanks - (Here is the info , for who that looking for it also)
http://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/Authentication/Dynamic%20Proxy%20RADIUS.htm
