  • 1.  UM2G Flags Mesh AP
    Posted May 04, 2018 02:22 PM
    Hi community I have configured a mesh network using aruba AP 335. One AP as mesh portal and another AP as mesh point. The mesh point boots and I can reach it by ping. But on the Mobility Master I'm seeing the UM2G Flags. (U= Unprovisioned, M= Mesh, 2: IKE ver 2 and G= no such group).
    I dont know if I have to do another config because I've already provisioned the AP and I assigned it to the ap-group where the mesh portal is.
    Thank you  in advance for your help.
  • 2.  RE: UM2G Flags Mesh AP
    Posted May 04, 2018 02:25 PM
    Reprovision that access point to an ap-group that exists on that controller.
  • 3.  RE: UM2G Flags Mesh AP
    Posted May 04, 2018 03:35 PM
    Hi cjoseph.
    I reprovisioned the ap to an ap-group and it kept the same flags.
  • 4.  RE: UM2G Flags Mesh AP
    Posted May 05, 2018 07:18 AM
    What version of ArubaOS is this?
  • 5.  RE: UM2G Flags Mesh AP
    Posted May 05, 2018 09:44 AM
    Version: 8.2.0.1
  • 6.  RE: UM2G Flags Mesh AP
    Posted May 05, 2018 11:06 AM
    Type "show log system 50" on the commandline of the MD to see if you have any clue why it has that flag..
  • 7.  RE: UM2G Flags Mesh AP
    Posted May 05, 2018 11:54 PM
    Hi cjoseph,
    Below I attached a txt with the output of the command.
    Thank you.
    Attachment(s)
    txt
    show log system 50.txt   8 KB 1 version
  • 8.  RE: UM2G Flags Mesh AP
    Posted May 06, 2018 09:36 AM
    There is no information in that output.  I would try to provision the AP without mesh and see if the G flag disappears.
  • 9.  RE: UM2G Flags Mesh AP
    Posted May 06, 2018 06:01 PM
    So you mean, provision it wired?
  • 10.  RE: UM2G Flags Mesh AP
    Posted May 06, 2018 07:02 PM
    Provision its mesh role as "none" and then reboot.  See if it comes up when you plug it in wired.
  • 11.  RE: UM2G Flags Mesh AP
    Posted May 07, 2018 10:41 AM
    Ok, I'll try that.
    Thank you.
  • 12.  RE: UM2G Flags Mesh AP
    Posted May 07, 2018 04:13 PM
    Update: So I decided to reset the AP to factory defaults and then I provisioned it as mesh point in the AP group where the rest of APs are. Finally I kept the mesh portal AP in the "mesh-ap" group. Now mesh is working properly.
