  • 1.  Unable to change AP group
    Posted Sep 25, 2024 11:13 AM
    I have a mobility conductor, controller setup, all virtual. I run 8.10.0.14_90752 on both controller and conductor.
    When I try to add an AP (345) to an AP group, it refuses to add the device to this new group.
    Every time the AP is provisioned which required the reboot the AP will stick to the "default" AP group
    Any suggestions?
    Martijn van Overbeek
    Architect, Netcraftsmen a BlueAlly Company
  • 2.  RE: Unable to change AP group
    Posted Sep 25, 2024 11:16 AM
    Check the provisioning rules and the assigned group in the allowlist.
  • 3.  RE: Unable to change AP group
    Posted Sep 25, 2024 01:01 PM
    If everything was as easy as this, thank you that worked, it turned out I had to edit the "Allowlist"
  • 4.  RE: Unable to change AP group
    Posted Sep 25, 2024 06:55 PM
    Highly recommend you not set the device name or group in the allow-list.
    Carson Hulcher, ACEX#110
  • 5.  RE: Unable to change AP group
    Posted Sep 26, 2024 06:21 AM
    Very much agree with Carsons advise. If you wont to have more flexibility to migrate APs from group to group and renaming them, then don't fix it in allow list.
    If you have those fixed, you will most probably forget to change allow list when moving/renaming APs and will be very upset as provisioning was not done as you think it will. Been then don that many times. It cost additional reboots and some bad will until you remember to do it the right way :-)
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
