Comware
Unable to enable 802.1x globally on HPE 1950 JG963A
  • 1.  Unable to enable 802.1x globally on HPE 1950 JG963A
    Posted Sep 11, 2018 10:43 AM
    I'm trying to setup 802.1x with a radius server and am following the example in the manual.
    The manual says the following:
    Configure 802.1X on the switch:
    a. From the navigation tree, select Security > Access Control > 802.1X.
    b. Enable 802.1X globally.
    c. Enable 802.1X on GigabitEthernet 1/0/1, and set the access control method to MAC-based.
    d. On the advanced settings page for GigabitEthernet 1/0/1, set the port authorization state to
    Auto and set the mandatory ISP domain to dm1X.
    When I go to Security, Access, 802.1X and click the Enable 802.1X button, I receive:
    Error
    Can't enable 802.1X for port security is enabled.
    I looked online for how to disable port security and found the following, but it wasn't very useful :-)
    https://www.youtube.com/watch?v=bO_dUTBcTOw
    A little help please.
  • 2.  RE: Unable to enable 802.1x globally on HPE 1950 JG963A
    Posted Sep 12, 2018 09:33 AM
    There is an option to disable port security.
    Go to Security tab in the web gui and you should find an option to disable port security there.
  • 3.  RE: Unable to enable 802.1x globally on HPE 1950 JG963A
    Posted Sep 12, 2018 10:46 AM
    Ah, the round power button at the top right.. Thanks.
