Comware
  • 1.  Unexpected restarts
    Posted Nov 04, 2008 05:31 PM
    One of my 2900's seems to be restarting randomly.
    This morning it affected backups and our time collection system.
    What should I be using to monitor / diagnose these issues? I have a feeling the switch is bouncing more often, and I'm only occasionally catching it.
  • 2.  RE: Unexpected restarts
    Posted Nov 05, 2008 04:42 AM
    Hi Daniel,
    You could start by identifying what is going on, the show tech (Show Technical Support) file, You will need a TFTP server, you can download one for free at www.solarwinds.com
    Use the following CLI command:
    copy command 'show tech all' tftp <TFTP server=""> <FILENAME> [*ENTER*]
    Me and my esteemed members on this forum, could assist in identifying the problem!
    Good Luck,
    Franklyn
    </FILENAME></TFTP>
  • 3.  RE: Unexpected restarts
    Posted Nov 05, 2008 09:11 AM
    Thanks.
    Here's a short clip:
    show boot-history
    Master -- Saved Crash Information (most recent first):
    SubSystem 0 went down: 11/04/08 05:26:33
    PPC Data Storage (Bus Error) exception vector 0x300:
    Stack Frame=0x089c6340 HW Addr=0x00baa114 IP=0x00765334 Task='mIpPktRecv' Task ID=0x89c6630
    fp: 0x0a8d7034
    CRASHLogfileshow
    ...Crash Log File Header..........................
    Product: ProCurve J9
    Name: ProCurve Switch 2900-24G
    Date: Jul 25 2008 10:41:52
    Build: 883
    Version: T.13.23
    Directory: /sw/code/build/mbm(t3a)
    CPU: PPC85XX
    crash index = 1
    boot type = Switch Reset
    willBootType = UNKNOWN BOOT
    CrashRecordPointer (0xffc9b7c) for Crash Record Index 1
    ----- Crash Record: 1 at 0xffc9b7c -----
    crash info = 0xbaabface
    subSystem ID = 0
    timestamp: 11/04/08 05:26:33
    Crash msg: PPC Data Storage (Bus Error) exception vector 0x300:
    fp: 0x0a8d7034
    CRASHData
    Length 701
    Rec Ptr 0xffcee5c
    cpu utilization = 4
    total free allocated min-free missed corrupt
    MSG_BUF 5200 4601 599 4471 0 0
    PKT_BUF 9000 7241 1759 7150 0 0
    Allocation statistics for MSG buffer pool:
    OwnerName OwnerID #Owned
    (null) 9560100 26
    mEaseCtrl 887f810 26
    muiCore 8c97470 9
    mLinkTest 840e0a0 2
    Allocation statistics for PKT buffer pool:
    tDevPollRx abeb270 1664
    mIpPktRecv 89c6630 95
    Slot 1
    CRASHLogfileshow
    slot a:
    Product: Procurve CA
    Name: Procurve Switch card id:08
    Date: Jul 25 2008 09:35:44
    Build: 866
    Version: T.13.23
    Directory: /sw/code/build/mbs(t3a)
    CPU: ARMARCH5
    crash index = 0
    boot type = POWER ON
    No Saved Crash Information
    CRASHData
    slot a:
    Length 25
    Rec Ptr 0x40002ca0
    No Crash data available!
    Slot 3
    CRASHLogfileshow
    slot c:
    Name: Procurve Switch card id:38
    Build: 866
    Version: T.13.23
    CPU: ARMARCH5
    crash index = 0
    CRASHData
    slot c:
    Length 25
    Rec Ptr 0x40002ca0
  • 4.  RE: Unexpected restarts
    Posted Nov 05, 2008 09:53 AM
    Hi Daniel, you are having the following buserrors:
    fp: 0x0a8d7034
    There is a fix implemented , you need to contact your local support for the following firmware release: T.13.25
    Good Luck!
  • 5.  RE: Unexpected restarts
    Posted Nov 05, 2008 02:08 PM
    Thank you.
    I called support and while the .25 release does not directly affect my issue, they did ask me to update and report back.
    I have a ticket open with support and will follow up here as well.
