  • 1.  Unlicensed AP after controller firmware upgrade
    Posted Jan 14, 2024 05:00 AM
    I tried to upgrade my Aruba controller 7205 firmware from 8.9 to 8.11 but after the successful upgrade, all AP becomes Unlicensed (L).
    I tried to test 1 AP to preload 8.11 firmware then reboot it, but still the 8.11 AP (172.100.5.116) is Unlicensed. I checked the Licenses tab and the license is still there but no AP is using it.
    I read the release notes of 8.11 before I upgrade and it is compatible with my controller 7205 and AP505, AP575.
    I have no choice but to reboot the controller to my old firmware 8.9 and it works fine even in my AP505 with 8.11 firmware.
    What could be the issue?
    Thank you.
  • 2.  RE: Unlicensed AP after controller firmware upgrade
    Posted Jan 14, 2024 04:35 PM
    That's strange. I would advise you to open an Aruba TAC case to investigate this, or to help you reschedule the update.
    Is this a standalone controller or a controller managed by a mobility conductor. My advice would be to update the mobility conductor first as this is also your license server.
    You indicate that you have restored a backup to the old version, so we cannot ask you to share logging.
    Your version is supported but my advice would be to only update production environments to a long support release (LSR) and that is 8.10.0.9 at the time of writing.
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: Unlicensed AP after controller firmware upgrade
    Posted Jan 14, 2024 09:31 PM
    Hi Marcel,
    I am only using a stand alone controller 7205. The only logs that I have from the access point is the attached files. I will try 8.10.0.9 LSR.
    Thank you.
    Attachment(s)
    csv
    plog-export (1).csv   21 KB 1 version
    csv
    plog-export.csv   21 KB 1 version
