Comware
  • 1.  Unsupported Mini Gbic
    Posted Jul 10, 2010 09:27 AM
    I have 5406zl (Version 14.47) with 24 Minigbic modul (J8076A)and 1000Base T Mini-GBIC (J8177C). The swictch tells me that this is Unsupported Transceiver. In same modul i have Gigabit-SX-LC Mini-GBIC (J4858C) and it works fine. Documentation clearly points that this should work.
    I appreciate some help if possible.
    Thanks in advance.
  • 2.  RE: Unsupported Mini Gbic
    Posted Jul 10, 2010 10:31 AM
    the SFP is supported, your firmware is suitable for this SFP. Try to log a call and let HP replace the SFP.
    Can you post the output of the command:
    show tech transceivers
    Patrick
  • 3.  RE: Unsupported Mini Gbic
    Posted Jul 11, 2010 06:05 PM
    Just for clarification can you check this Mini-GBIC on another switch and see if it will be detected and will be supported.
  • 4.  RE: Unsupported Mini Gbic
    Posted Jul 12, 2010 02:23 AM
    I attached output for sh tech transceivers.
    Switch complaints that it is Not a ProCurve Transceiver. I will try to upgrade to latest K14.60 software. If that dosn`t help i will call HP.
    Thanks for quick replay.
    Best Regards
  • 5.  RE: Unsupported Mini Gbic
    Posted Jul 12, 2010 03:00 AM
    I don't know if this may be related or not, but if using this m-gbic in a 20+4 module, it will only work in the lower row -or- upper row, but not both at the same time. See this link: http://h10144.www1.hp.com/products/accessories/J8177B/accessory.htm
    Maybe try removing all of these in one of the rows and see what gets reported???? maybe worth a try.
    (I realize youare not using this module in the note, but I thought it worth mentioning)
    hth...Jeff
  • 6.  RE: Unsupported Mini Gbic
    Posted Jul 12, 2010 03:27 AM
    Tried to put in one raw and no help.
    Thanks everybody for help.
  • 7.  RE: Unsupported Mini Gbic
    Posted Jul 12, 2010 07:47 AM
    I can see you have multiple trans. of the same kind that are showing not supported, in this case you might have non-genuine trans.
    please double check
