Howdy,
Got a weird problem with a gbic transceiver and a 2610. Device info:
Switch 2610-48-PWR J9089A
Firmware: R.11.54
Multimode GBIC: part no J4858C
log shows self test failure:
05/31/11 22:00:29 FFI: Port 52 self test failure
05/31/11 22:00:56 ports: port 52 xcvr hot-swap remove.
show tech transceivers shows that its "unsupported"
Transceiver Technical Information:
Port # | Type | Prod # | Serial # | Part #
51 | 1000SX | J4858C | MY049VM6F5 | 1990-3657
52 | ?? | ?? | unsupported |
The following transceivers have extra information:
Port # Message
Port 52 Self test failure.
Port 51 has the exact same part in it and when moved to Port 52 it works. That GBIC is a little older (was installed 6 months) and I recently got a new batch - I've tried 3 'new' ones and all of them exact same problem. I also had a brand new 2610 all 'new' GBICs same problem - when I try the same 'new' GBICs on a 6200 they work.
I'm wondering if anyone else has experienced this issue?
