Or a counterfeit transceiver trying to make you think it was an authentic Aruba transceiver. It happens more than you think -- and it really damages our reputation when something that say Aruba fails (and it isn't even ours !!!)
Your check using the Phone app from the Validate site was a good check. I wonder what the result is with the 'faulty' units you had from before.
Thanks for being a HPE Networking/HPE Aruba customer.
Ed Kurata, Aruba Sr. Product Line Manager,
Switching , Transceivers, Accessories, Power, and other things
Roseville CA, USA
Original Message:
Sent: Sep 02, 2019 10:58 AM
Subject: Unsupported Transceiver
just received new transceivers, not exactly the same design for the package. But running fine.
with the new transceiver I used the link www.hpe.com/producs/validate, and put one of the SID with failure, it's OK HP device.
so definitely thinking about manufacture error.
