Developer
Updating AP location in visualRF with XML API using python
  • 1.  Updating AP location in visualRF with XML API using python
    Posted Aug 24, 2023 01:00 PM
    Hi!
    I'm a learn by example type and can't seem to find anything to help me get the syntax right to update AP information using the "add_access_points" API (below)
    Does anyone have sample code with the correct way to use "requests" to update x, y locations for a given ap_id?
    Thank you!
    --Doug
    Access Point Add/Update
    URL
    https://amp.airwave.com/visualrf/add_access_points
    XML Schema
    visualrf_site_access_points.xsd
    Parameters
    site_id: ID of the Site to add access points
    xml XML: document following the above schema
    When adding a planned AP, omit the id attribute and supply manufacturer and model Planning requires radio phy attribute Only AP name, x and y may be updated Only radio beamwidth, orientation, gain and mount may be updated
    Example:
    <?xml version='1.0' encoding='ISO-8859-1'?>
    <visualrf:site_access_points xmlns:visualrf='http://www.airwave.com' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' version='1'>
        <ap id='12660' x='50' y='80'>
            <radio index='1' beamwidth='180' orientation='90' gain='2.5' mount='ceiling'/>
        </ap>
    </visualrf:site_access_points>
  • 2.  RE: Updating AP location in visualRF with XML API using python
    Posted Sep 22, 2023 02:25 PM
    I've spent some trial and error with variations of session.patch, session.put and xml to update the AP x= and y= locations on a floorplan. The response code says "success", but I am not seeing the AP move on the floorplan.
    This is my test code that uses the site-id of the floorplan and xml and calls the API:
    xml_update_ap_visualrf = """
    <ap id='98' x='42' y='42'>
    </ap>
        def update_xml(self, site_id='c442b340-a567-4716-9648-fe9b2b0c2af4' ):
            xml_headers = {'Content-Type': 'application/xml'}
            add_visualrf_url = self.api_path('/visualrf/add_access_points')
            xml_data = xml_update_ap_visualrf
            params = {'site_id': site_id,
                      'xml': xml_data }
            params = Airwave.urlencode(params)
            response = self.session.put(add_visualrf_url, headers=xml_headers, params=params, verify=False)
            print(response.text)
            return response
    This is what I get back:
    <?xml version="1.0" encoding="UTF-8"?>
    <visualrf:results xmlns:visualrf="http://www.airwave.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><success/></visualrf:results>
    Is this the right forum to get help/support for the Airwave/visualRF API ?
    Thanks in advance!
    --Doug
