Comware
Upgrade 2930M in stack without downtime
Jump to Best Answer
This thread has been viewed 16 times
  • 1.  Upgrade 2930M in stack without downtime
    Posted May 19, 2022 09:15 AM
    I have a stack of two switches 2930M ( JL083A ) in software version WC.16.10.0005 and I would like to know if it is possible to upgrade in release WC.16.10.0020 but without total outage ?
    I mean upgrading member one 1 then member 2 so the servers with dual attachment will keep connectivity.
    Thanks in advance four your advices.
    Eric Nicault
  • 2.  RE: Upgrade 2930M in stack without downtime
    MVP GURU
    Posted May 19, 2022 03:18 PM
    Hello Eric, unfortunately the backplane stacking implementation on Aruba 2930M (same for Aruba 2920) doesn't support a sequenced update of its members (say Standby first and then Conductor, as example). The entire stack needs to be rebooted in case of software update (so each stack member reboots concurrently with the others following the Conductor orders). This means that connected peers, even if dual connected to stack's members, will lose their connectivity towards the entire stack.
    Davide Poletto
  • 3.  RE: Upgrade 2930M in stack without downtime
    Posted May 20, 2022 02:56 AM
    Thank you for this clear response.
    Eric Nicault
  • 4.  RE: Upgrade 2930M in stack without downtime
    No :(
    Steinar Grande
