  • 1.  Upgrade Aruba AP505 firmware
    Posted Apr 16, 2024 09:06 AM
    Is it recommended to upgrade the Aruba AP505 firmware in this page ?
    this is is Aruba Central
    Can i use this method to upgrade the firmware 1 by 1?
  • 2.  RE: Upgrade Aruba AP505 firmware
    Posted Apr 16, 2024 09:27 AM
    There, or in any view through the Firmware menu that is listing the various devices you can click on the button at the far right, or you can multi-select and choose to upgrade specific devices.
    Carson Hulcher, ACEX#110
  • 3.  RE: Upgrade Aruba AP505 firmware
    Posted Apr 16, 2024 08:52 PM
    what is the next available firmware i should upgrade for AP505?
    i am using 8.7.1.6_81786.
  • 4.  RE: Upgrade Aruba AP505 firmware
    Posted Apr 16, 2024 08:59 PM
    8.10 or 8.12.
  • 5.  RE: Upgrade Aruba AP505 firmware
    Posted Sep 07, 2024 04:18 AM
    what is the difference between 8.10 and 8.12 ?
  • 6.  RE: Upgrade Aruba AP505 firmware
    Posted Sep 19, 2024 03:30 AM
    As I understand it, 8.10 is deemed a LSR (Long Supported Release) where as 8.12 is a standard release (which has newer features, but risks going EOL quickly [this can be sometimes six months or less].  All depends on your environment and how mission critical your infrastructure is and how quickly you need new functions vs. long term supportability.
  • 7.  RE: Upgrade Aruba AP505 firmware
    Posted Apr 18, 2024 11:18 AM
    8.7.1.6 is very broken IMHO.  Get yourself onto 8.10.0.10 branch for a far more stable system
